i got some questions
first off i want to run a single turbo on my soarer 1jz thats in my mk3 supra
and ive been looking at the driftmotion set up such as the 57 trim and 60 and i was wondering if which to go with if i have a goal of around 400hp and what size .ar is best and is there a better setup for my goals'
second what size injectors would be good and who makes a good fuel pressure regulator
third what woulfd i need to tun it, arc, boost controller, etc
i could use some advice on this guy so feed back would be awsome, i plan on running this on stock internals for now just too get the set up good and then plan on buying a whole nother engine to rebuild
about how much bosst would i have to run, what would 20psi produce?
