IC size
noel
Uchiha Member
May 5, 2008
512
Miami, Florida, United States
rabidchimp;1219829 said:
You can get an intercooler as wide as 30" in there without modiftying the bumper cover itself.
-Aaron
really so something like 30x12x3 is okay im sure i would have to relocate the oil cooler and the coolant bottle correct???
if i had to relocate that oil cooler where should it be ??
DavidBaustert
Dayton Ohio
Buy an aftermarket oil cooler if you plan on modding in the future. Before I upgraded mine I just moved it to where the AC condensor used to be. When plumbing the new one use transmission line, not emissions hose.
shiftysupra
180
Tucson, AZ
I put in a 32x24x3. It's pretty big and you will have to remove the a/c condenser and lines, the oil (mine was power steering) cooler as well as the overflow bottle.
noel
Uchiha Member
May 5, 2008
512
i have no problem relocATING the coolant bottle and the oil cooler but in what way can you upgrade an oil cooler???
ummm... i WANNA keep my a/c FLORIDA is HOTTT!! and it actually works lloll
