I removed the cruise control
xcyanideslethalx
7M Boy aka LaaagMaster
Sep 6, 2007
56
burlington,washington
from under the hood and no after i did that i now have some type of sound like air pushing past something its like near the intake manifold and i did block off all of the extra vacumm ports im not that dumb could it be the orings around the injectors?
xcyanideslethalx
Sep 6, 2007
56
ya but it tees off into the boost sensor but i dont know where the sounds coming from its like the intake area and i dunno its a waeird sound its not there when the cars dead cold but when it warms up then it starts making the sound
gaboonviper85
3,236
Northeast Philly
pick up some cans of trottle body cleaner and hose the intake down while car is warm and makeong the sound...if the idle starts changeing then you will know forsure you have a vac leak...that vac leak will turn to a boost leak and cause the car to run damn rich...hope you find it...if it wasnt there before I dont know why its there now cause you shouldn't need to take the intake off to remove cruise
