I need help asap
yayfish24
56
avondale pa
Im rebuilding a friends supercharged mr2 but I cannot seem to find any specs for the cylinder head or block. Ive searched maybe 15-20 sites with no results. Any one know where I can find the specs? Im looking for specs on everything. Please help me out.
Thanks
yayfish24
56
avondale pa
I found what I needed before checking out mr2oc.com but thanks for the help. Ill take some pics tomorrow and show what im doing. ONce again thanks.
toyotanos
What will we break today?
2,844
Coon Rapids, MN
What kind of specs do you need? Also, what are you doing to the engine?
Please specify which year the car is- I would suspect an 88-89 Aw11 SC, but it could be a 91+ 3SGTE, too. I can get the info for you, but I need specifics!
I used to own an 89 SC and I loved that thing! Cornered like a monster and pulled hard @13psi! Fun car.
yayfish24
56
avondale pa
I beleive the car is an 89. The car was bought only for the engine and the body may be getting junked or I might buy it. I was look to specs on the valves, valve to guide clearance, spring pressures and maxium amount that can be bored in the cylinders. Ive found everything but the boring limit. Any idea how much is too much?
