i need a pic someone posted a while a while back
supra_man87
EL GUAPO
Nov 15, 2007
241
So. Col.
hey, i was looking for a pic that i saw a while back. i is showing a supra halfway on a lift being burped. i think it was borhor that posted it, but i can;t find it anywhere. i wanted to see how that was actually being done. thanks
black91turbo
Formerly black87turbo
Apr 27, 2006
1,064
Jacksonville, FL
cant help you with the pic but you can buy a funnel that fit snuggly into the radiator opening at the parts store....take off the radiator cap, put the funnel in...get it about half full with water and turn on your heater....That is how I did mine....just thought i would share...
supra_man87
EL GUAPO
Nov 15, 2007
241
So. Col.
Big Wang Bandit;996604 said:
Was it at a shop?
I think blackMK3 posted it
yeah it was in a shop. i'll try and find it that way. and its not that i need help with filling the coolant system, cause i've had my share, but i wanted to find it. thanks.
gofastgeorge
944
Texas
Right on NashMan......
Seems like this was all just covered not 3 weeks ago in this thread:
http://www.supramania.com/forums/showthread.php?t=68707
When you do the purge, make sure your heater is set on high, and turned on.
This gets out any air that may be hiding in your heater core.
And if you do all this, and still end up with air in the radiator.......
Most likely you have a head gasket starting to leak high pressure combustion gas into the water jackets.
tissimo
Stock is boring :(
Melbourne, FL
just fill it with coolant run it for a few minutes top it off and fill up the reservoir and call it a day.. no need for voodoo lift the front end etc
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Yea i never lifted the front of my car to put coolant it in. I just cranked it up with the heat on and let it get warm..Then topped it off. No air in mine :dunno:
