i figured out why my car shakes while braking
chefma70
404
Florida
not warped rotors......me and a friend a supra owner changed my rotors and brake pads hoping to fix my car rattle problem.
after taking the wheels off i noticed my friggen passenger side caliper is bieng held on by 1 bolt the entire caliper swings like a door hinge!!!!!!!! there is 3 bolts that hold the caliper in place 2 main ones and a smaller one well i found out im missing one of the main ones on my left side:aigo::3d_frown:.part should be in today:icon_bigg i will finally have normal brakes:biglaugh:
grimreaper
2,180
Dallas
3? two hold the caliper to the bracket, 2 hold the bracket to the suspension. I did all 4 corners few months back and cant remember 3...
chefma70
404
Florida
bracket to suspention??????
did i mention my short term memory is missing lately maybe it was 4?
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Cant remember if our brakes are this way but sometimes one of the pins is part of the bracket and you just remove the lower bolt, swing the caliper and then slide it off
it is 2 and 2 so 4 total but just remove the top one and swing it off one less bolt.
It's 1 and 2 as the top slide is part of the body of the caliper and the pin is on the bracket...
Bracket is attached to the the hub by two bolts. It's a pretty good design since if the one bolt holding the caliper in place falls out you're still fine for a short while (unlike some cars where the caliper will swing out and jam against the wheel). But of course if the slids are screwed it gets to be a pain (bad slides cause issues as well)
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
i thought there are two bolts to take the caliper itself out with the brake pads, but the caliper support have 2 more bolts ?
grimreaper
2,180
Dallas
poodles how many times have you taken your car apart?! you usually know all the little odd ball stuff like this!
IndyMK3
I Hate Godzilla Too!!!!
May 15, 2008
323
Indianapolis, Indiana
there is one bolt holding the caliper to the bracket, it is located on the botom... then you can swing the caliper up and off of the stationary slider... if you buy a brake hardware kit you can replace the stationary slider, there is one bolt holding that on... there is two small bolts holding on the brake hose to the bracket, and then two more bolts holding on the bracket.
hope that can help =)
Haven't had my car apart THAT many times, but as I had to fix the stupid stuck slides on 3 of the calipers whne I bought the car, I remember fighting with the design.
Personally hate sliding calipers, it's a shitty design and when the system wears it can cause issues...
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Yep I did my brakes a few weeks ago and was surprised by a stuck slide. What a pain the the fucking ass to get the slide out without messing anything up..
vdragonmpc
tireflaminrumpshaker
Apr 11, 2005
300
Colonial Heights
www.joncjennings.com
I know that thing just doesnt want to come out. I have a special techique involving some screaming and good vocabulary along with a possible threat to crush the car slowly.
I had to do the passenger side of my car that was originally from pennsylvania. It was on there but good.
