I broke a sensor. help
SimpleIcon
Brigadier General
ok, if your looking at the engine from the front of the car, theres about 5 sensors that are in the general area of where the radiator pipe goes into the engine. ... I broke one of them. Where is there a diagram that can tell me which one it is so i can go get it from a shop? or... maybe just a diagram that tells me how important it is....
or... if thats impossible, how do i get another?
stupid fragile ceramic sensors...:nono:
MKIIINA
Destroyer of Turbos
Plano, TX
sounds like you might have snapped off of the thermostat. post a pic of the one you broke and we can help you better.
SimpleIcon
Brigadier General
I dont think i snaped off the thermostat
ill get a pic up maybe sunday
supraman7mgte
Shut up,bitch!!
Sunny California
It could be one of many sensors.One is for the temp gauge,another for the A/C sensor,another for the A/C fans and the last I think is a temp/vac sensor,it has 2 vac lines going to it.
IHI-RHC7
"The Boss"
Oregon
yep, that's the thermostat. You better replace it...
Which sensor did you break?
one of the three on "top" or one of the twoo down low/ behind things?
Or was it the one with vaccum lines on it that goes to the charcoal canister?
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
This pic looks a bit easier to follow. No offense IHI-RHC7 :icon_bigg
eric
