Hypothetically speaking....
radiod
1,342
Abbotsford, BC
I believe the car would run....just real crappy though dumping tons and tons of fuel in to compensate for no AFM readings. Why would you want to do such a thing?
Dec 13, 2006
Illinois
i would never wat to do that, that'd be crazy, i was just wondering wat would happen if they were cut.
radiod
1,342
Abbotsford, BC
You have a sick sick mind to think of doing such things to your car just to see what would happen :icon_razz:icon_razz:icon_razz
8,898
dababiboi786/supramaniac;1031654 said:
Hypothetically speaking what would happen if i cut the wire running from the MAP sensor to the ECU, or The AFM to the ECU?
In reality and not hypothetically, you don't have a MAP sensor, unless you are VPC or MAFT-Pro.
The short answer is the ECU will substitute a known good value. If JJ gives you a long answer, then you will know more.
