hp numbers
max-89supra(t)
153
vancouver, wa
hey guys do you know about how much hp a mostly stock manual 7mgte would make on 12 lbs of boost? numbers dont gotta be exact cuz i know there are a million mods that affect the numbers, but about how much- wheel or crank hp? thanks.
8,897
HKS claimed in their catalog that with a manual boost controller set to 11.5, and their exhaust you will be at 285 bhp.
On my car with the down pipe and exhaust, set at 13, with an automatic, I calcuated about that amount with my ET, speed, and mph. So I know it is close. In other words, a lot more fun.
CzA
99
Toronto
i put down 274HP to the wheel so around 328(approx) from the crank,
Mods, 12.4 psi. 3 inch elbow back(no cat), intake.
MasonF
11
Temecula, CA (SoCal)
Wow...nice. I'm in for a treat when I do my 7M-GTE swap then. I'm used to the 1.6 4A-GE and the 2.0 3S-GTE...it will be nice to feel some real power. :D
wiseco7mgt
dirty mechanic
Aug 12, 2007
811
queensland
Yeah should feel alot more but shame you have to factor in the extra body weight.
8,897
Don't count on 274 at the wheel with just a boost controller and exhaust at 12 psi. That is quite the generous dyno. Or more mods.
For example.
isnms - 268.40whp/299.13wtq - k&n fipk, cartech ic series 2, defcon ic hardpipes, ct26 50trim, BIC 3"dp, high flow cat, 3" cat back, cometic, spec stage2, hks s-afr
17.
15. xarewhyayen - 272.94whp/324.75wtq - mhg/arp studs, 3" elbow w/ HKS replica 3" dp, test pipe, Tanabe Hyper Medallion Cat Back, Greddy Profec E01, Upper hardpipe w/ Greddy Type RS, K&N w/ LIPP adapter. Spec stage 3
With tuning, that is defintely approachable with a fresh motor.
