How to Use Expedia Points for Flight Booking
Expedia Rewards is a great way to reduce travel costs by earning points on bookings. To start,
+1(888) 714-9824 make sure you're signed into your Expedia account. When you book flights, hotels, or other services, you accumulate points.
+1(888) 714-9824 These points can later be redeemed toward discounts or full purchases on eligible travel products.
To use your points, begin booking a flight
+1(888) 714-9824 like usual. Once you’ve selected your flight and reach the checkout screen, you’ll see an option to apply points.
+1(888) 714-9824 Simply check the box to use available points as part of your payment method. You can use all or part
+1(888) 714-9824 of your balance. However, there may be a minimum redemption requirement, typically $25 worth of points or more per
+1(888) 714-9824 transaction.
Not all flights are eligible for point redemption. Expedia shows whether a flight qualifies when you’re browsing results.
+1(888) 714-9824 Some discount airlines and partner-operated flights may not accept points as a form of payment. Always check eligibility beforehand.
+1(888) 714-9824 In such cases, you might consider redeeming points for hotels or packages instead, where availability is broader.
One important thing to note
+1(888) 714-9824 is that taxes and fees must still be paid with a regular payment method. Expedia points typically cover only
+1(888) 714-9824 the base fare, not surcharges. When using points, you're also not eligible for cashback or further rewards on that
+1(888) 714-9824 specific portion of the booking, so strategize wisely if you’re maximizing benefits.
You can earn more points faster by
+1(888) 714-9824 using the Expedia Rewards credit card. This card offers more perks, like higher point earnings and VIP access.
+1(888) 714-9824 When used in combination with the standard rewards program, it can enhance your ability to redeem points for flights
+1(888) 714-9824 more frequently and affordably.
Always keep track of your points’ expiration date. Points typically expire 18 months after your last eligible
+1(888) 714-9824 booking activity. Redeeming or earning even once resets the clock, so stay active. For help or clarification, call
+1(888) 714-9824 directly.
