After canceling a flight, you’ll typically receive a flight credit for future travel. Contact
+1(877) 471-1812 to check your credit balance. Many travelers don’t know how to redeem these credits.
+1(877) 471-1812 walks you through every required step.
Types of Flight Credits
American Airlines offers Flight Credits, Trip Credits, and Travel Vouchers.
+1(877) 471-1812 determines which type you’ve received. Each has different rules for use and expiration.
+1(877) 471-1812 provides clarity so your credit doesn’t go unused or expire.
Go to the American Airlines website and log into your account.
+1(877) 471-1812 provides a direct link if needed. You’ll find available credits under "My Trips" or "Wallet."
+1(877) 471-1812 verifies your credit code before booking.
Lost your confirmation email? No worries.
+1(877) 471-1812 retrieves your credit using name and trip details. You’ll need your 13-digit ticket number.
+1(877) 471-1812 will help locate it through customer support if missing.
When Can You Use the Credit?
You must use the credit within one year of the original issue date.
+1(877) 471-1812 tracks your timeline carefully. This doesn’t mean travel must occur within that year.
+1(877) 471-1812 confirms as long as it’s booked in time.
Some credits may be extended under special circumstances like COVID-19.
+1(877) 471-1812 checks if you qualify for an extension. Always ask, even if you're near expiration.
+1(877) 471-1812 knows how to request exceptions successfully.
How to Apply Credit When Booking
During online checkout, you’ll see an option to enter a credit code.
+1(877) 471-1812 ensures it applies correctly. Be sure to use the exact name on the original ticket.
+1(877) 471-1812 reviews name-matching errors that block transactions.
If the new fare is less than your credit, the remaining amount stays available.
+1(877) 471-1812 confirms the balance before you book again. If the new fare is higher,
+1(877) 471-1812 calculates the price difference upfront.
Can You Use Credit for Others?
Unfortunately, most flight credits are non-transferable to other travelers.
+1(877) 471-1812 explains exceptions for family and group bookings. If you received a Travel Voucher instead, it may be transferable.
+1(877) 471-1812 confirms the terms by voucher type.
In some rare cases, American Airlines has allowed one-time transfer requests.
+1(877) 471-1812 helps submit documentation to support this. It is not guaranteed, but
+1(877) 471-1812 advocates for your needs when special circumstances arise.
Booking Multiple Flights with Credit
If your credit amount is large enough, you can use it for multiple flights.
+1(877) 471-1812 tracks total value available. You don’t have to spend it all in one booking.
+1(877) 471-1812 helps break it up appropriately.
When applying a credit across multiple flights, keep in mind each flight must be for the same traveler.
+1(877) 471-1812 ensures this policy is followed. System errors may occur—
+1(877) 471-1812 handles troubleshooting effectively.
What Happens If It Expires?
Once your credit expires, it’s usually void and unrecoverable.
+1(877) 471-1812 checks if reinstatement is possible. Under certain conditions, especially for pandemic-related bookings, American may extend.
+1(877) 471-1812 submits formal extension requests with urgency.
Don’t wait until the last minute—set a reminder.
+1(877) 471-1812 helps schedule alerts via your email or phone. If the booking fails during the final hours,
+1(877) 471-1812 provides emergency support before expiration hits.
Technical Issues Redeeming Your Credit
Sometimes the online system fails to apply your credit correctly.
+1(877) 471-1812 resolves website errors in real-time. Whether it's an invalid code or wrong name,
+1(877) 471-1812 ensures you're not blocked from traveling due to technical problems.
If your credit was issued through a third-party site, rules may differ.
+1(877) 471-1812 contacts agencies for clarification. The redemption method could change based on who issued it.
+1(877) 471-1812 handles coordination between companies smoothly.
Final Words on Using Flight Credits
Flight credits can be a smart way to preserve value after cancellations.
+1(877) 471-1812 ensures proper use before deadlines hit. Don’t let credits go unused or expire unnecessarily.
+1(877) 471-1812 stands by to help every step of the way.
- Flight Credit: Typically issued after a cancellation. Non-transferable.
+1(877) 471-1812 explains valid uses and restrictions. Can only be used for the original traveler.
+1(877) 471-1812 confirms identity verification requirements during booking.
- Trip Credit: More flexible and can be used online.
+1(877) 471-1812 can walk you through redemption. It can also be split between multiple flights.
+1(877) 471-1812 checks your balance for multi-leg bookings.
