How to Solve Brother Printer not Connecting to WiFi Issue
potterhagrid007
8
Brother printers are known for their easy-to-use features and good print quality. Many people prefer using wireless printers because they are convenient and reduce the need for cables. However, sometimes your Brother printer not connecting to WiFi +1-803-866-1601, which can be frustrating. The good news is that this problem can usually be fixed by following a few simple steps.
Why Is My Brother Printer Not Connecting to WiFi?
There can be several reasons why your Brother printer won't connect to WiFi +1-803-866-1601. Some of the most common causes include:
  • Incorrect WiFi password
  • Printer too far from the WiFi router
  • Weak or unstable internet connection
  • Outdated printer software or drivers
  • Wrong network selected on the printer
  • Firewall or antivirus blocking the connection
  • Printer settings not configured properly
Once you know what might be causing the problem, it becomes easier to fix it.
How to Fix Brother Printer Not Connecting to WiFi
Here are simple steps you can follow to reconnect your Brother printer to your WiFi network.
1. Check WiFi Network and Password
The first thing you should do is check your WiFi connection and password.
  • Make sure your WiFi is working properly.
  • Confirm that other devices like your phone or laptop are connected to the same network.
  • Double-check your WiFi password for accuracy.
  • If you recently changed your WiFi password, you’ll need to update it on your Brother printer too.
2. Restart Printer, Router, and Computer
Sometimes, a simple restart can fix small problems.
  • Turn off your Brother printer.
  • Unplug your router and wait for about 30 seconds.
  • Plug the router back in and wait for it to reconnect to the internet.
  • Turn your printer back on and try connecting it to WiFi again.
3. Move the Printer Closer to the Router
If your printer is too far from the router or if there are walls and obstacles in between, the WiFi signal might be weak.
  • Move your Brother printer closer to your WiFi router.
  • Make sure there’s a clear path without too many obstacles.
  • Try reconnecting to WiFi after moving the printer.
4. Reconnect WiFi on the Printer
If your printer is connected to the wrong network or the connection has been lost, reconnect it.
Follow these steps:
  • Go to your printer’s menu or settings.
  • Select Network Settings.
  • Choose WiFi Setup Wizard.
  • The printer will search for available WiFi networks.
  • Select your WiFi network from the list.
  • Enter the correct WiFi password carefully.
  • Confirm and connect.
Once connected, the printer should display a message like “Connected to Wireless Network”.
5. Update Printer Drivers
Outdated printer drivers can cause connection problems.
  • Visit the official Brother support website.
  • Enter your printer model.
  • Download and install the latest drivers and software for your operating system.
  • Restart your computer and printer after updating.
This ensures your devices communicate properly over WiFi.
6. Disable Firewall or Antivirus Temporarily
Sometimes, your computer’s firewall or antivirus software can block the printer from connecting.
  • Temporarily turn off your firewall or antivirus software.
  • Try connecting your Brother printer to WiFi again.
  • If it works, add your printer software to the firewall’s exceptions or allowed list.
  • Turn your firewall or antivirus back on after setting the exception.
7. Reset Network Settings on Printer
If nothing works, resetting your printer’s network settings can help.
To reset:
  • Go to your Brother printer’s menu.
  • Choose Network Settings.
  • Select Network Reset or Reset Network Settings.
  • Confirm the reset.
Once done, set up the WiFi connection again using the WiFi Setup Wizard.
Tips to Prevent WiFi Connection Issues
To avoid this problem in the future, you can follow these easy tips:
  • Keep your printer’s firmware and drivers updated.
  • Make sure your WiFi router is placed in a central and open area.
  • Avoid changing your WiFi name or password frequently.
  • Restart your printer and router occasionally.
  • Use a stable and strong internet connection.
  • Keep your Brother printer’s WiFi signal strength in check.
When to Contact Brother Support
If you have tried all these steps and your Brother printer won't connect to WiFi +1-803-866-1601, there might be a hardware issue or a technical fault.
In that case:
  • Visit the Brother official support page.
  • Use the online troubleshooting tools.
  • Contact Brother customer support for further assistance.
They can guide you with advanced solutions or help you repair your printer if it’s under warranty.
Conclusion
A Brother printer won't connect to WiFi +1-803-866-1601 is a common issue, but it’s usually simple to fix. By checking your WiFi password, moving the printer closer to the router, updating drivers, and resetting network settings, you can quickly solve the problem.
