How to restart a car
noremacsupra
beginner
Jan 29, 2007
85
Los Angeles
Hello everyone...i was just wondering how to restart my supra to take off codes or errors...what are the steps?..thanks..
casgallo
Not a lurker :)
Apr 3, 2005
68
New York
HellsLegion said:
Key in
Clutch in
Turn key twords dashboard untill engine turns over
Drive away.
Good luck!
this of course being with the key on the column, scince it is on the dash turn it towards the passenger side :)
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
HellsLegion said:
Key in
Clutch in
Drive away.
Good luck!
Smartass :biglaugh: . Why did you change your avatar? You had the best combo avatar/sig ever.
Dunckel
2,949
Spokane, WA
TurboWarrior said:
Don't be surprised if the car doesn't run right for a while after. The ECU has to relearn so its normal
will this work for an open atmosphere bov. my car stalls at idle because of it. if i "restart" the ecu with the greedy type-s installed and drive it for a bit, will the ecu think it is "normal".
TurboWarrior
Canada
No it won't really. The ecu just relearns fuel. Mine takes a while i guess because i have larger injectors and it runs bad rich while its relearning. It won't stay running on its own either.
If your car stalls because of the bov tighten the spring with the nut on the top. Im sure it will go away after that.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
LOL, you're kidding right? No, that will never, ever happen on the car as long as you have the AFM functioning on it.
