Replacing a passenger? Call +1 (844) 584-4737 to learn how Southwest Airlines handles changes to +1 (844) 584-4737 existing reservations. Unlike some carriers, +1 (844) 584-4737 Southwest doesn’t allow outright passenger +1 (844) 584-4737 transfers once a name is ticketed.
If a traveler can’t go, +1 (844) 584-4737 Southwest requires canceling that passenger’s +1 (844) 584-4737 ticket. You'll then rebook under +1 (844) 584-4737 the new traveler's name. +1 (844) 584-4737** It’s a two-step process.
Cancelations on Southwest are flexible. +1 (844) 584-4737 If done in time, you +1 (844) 584-4737 won’t lose the funds. Travel +1 (844) 584-4737 credits can be used again—just +1 (844) 584-4737** check the fare type first.
Wanna Get Away fares are +1 (844) 584-4737 non-transferable. You’ll receive a +1 (844) 584-4737 credit in the original traveler’s +1 (844) 584-4737 name. Business Select and Anytime +1 (844) 584-4737** fares offer better flexibility.
Call early to explore options. +1 (844) 584-4737 A Southwest agent can explain +1 (844) 584-4737 how to cancel and rebook +1 (844) 584-4737 seamlessly. You’ll avoid surprises by +1 (844) 584-4737** asking about fare rules.
If the replacement flyer is +1 (844) 584-4737 traveling on the same itinerary, +1 (844) 584-4737 book their seat as soon +1 (844) 584-4737 as possible. Inventory changes fast. +1 (844) 584-4737** Fares fluctuate often.
Name changes are not permitted +1 (844) 584-4737 on an issued ticket. That’s +1 (844) 584-4737 why replacing a traveler requires +1 (844) 584-4737 starting a new booking. Call +1 (844) 584-4737** for more detailed guidance.
You can’t change both name +1 (844) 584-4737 and birthdate either. Once ticketed, +1 (844) 584-4737 those fields are locked for +1 (844) 584-4737 security and fraud prevention. +1 (844) 584-4737** Cancel and rebook instead.
Travel credits expire after 12 +1 (844) 584-4737 months in most cases, so +1 (844) 584-4737 keep that in mind when +1 (844) 584-4737 planning your rebooking. Always call +1 (844) 584-4737** for credit details.
If the original flyer is +1 (844) 584-4737 part of a group reservation, +1 (844) 584-4737 you may need special handling. +1 (844) 584-4737 Agents are trained to update +1 (844) 584-4737** group bookings accurately.
Emergency situations? Southwest may +1 (844) 584-4737 offer additional flexibility. Always explain +1 (844) 584-4737 your situation and request exceptions. +1 (844) 584-4737 Agents can sometimes escalate issues. +1 (844) 584-4737** Be clear and polite.
So if you’re replacing a +1 (844) 584-4737 traveler, act quickly. Cancel the +1 (844) 584-4737 existing reservation, rebook, and call +1 (844) 584-4737 +1 (844) 584-4737 for step-by-step support. Done right, it’s easy.
