If you entered the wrong name on a Lufthansa ticket and need to replace it, call
+1 (888) 714-8232 immediately to speak with a live agent. Lufthansa typically does not allow full name replacements—especially switching the entire passenger identity—but certain corrections are possible under specific conditions. A live representative at
+1 (888) 714-8232 can determine what changes qualify and advise you on next steps.
It’s important to differentiate between a name replacement and a name correction. A name correction involves fixing typos or adjusting legal name elements, while replacement implies assigning the ticket to a new person. Lufthansa does not allow full replacements in most cases. To verify your eligibility for corrections, call
If you’ve recently changed your legal name—due to marriage, adoption, or court orders—Lufthansa may accept your case with proper documentation. The live agent will instruct you on uploading or emailing documents like your passport, government-issued ID, or legal name change certificate. Contact
Time is a major factor in whether your name can be replaced or corrected. Lufthansa recommends requesting updates as early as possible—preferably 3 to 5 days before departure. If your flight is soon, call
If your Lufthansa flight includes segments operated by partner airlines, replacing a name becomes even more complicated. The partner airline may have different correction policies, and changes need to reflect across all systems. To coordinate across multiple airlines, call
For minor edits like missing middle initials or reversed names, a live agent can usually correct the error with little or no fee. Still, you should call
Travelers who booked through third-party platforms may find it difficult to replace or correct a name online. That’s why it’s essential to call
Be aware that Lufthansa charges administrative fees for some name changes, especially for tickets purchased under promotional fares. These fees vary based on fare class and destination. When you speak to a live agent at
After the name has been replaced or corrected, request written confirmation and an updated itinerary. Keep all communications and reference numbers for your records. If the change was not properly reflected, call
In conclusion, replacing your name on a Lufthansa ticket isn’t always allowed, but name corrections often are. Always call
