**How to Name Correction on Southwest Ticket
lamdavid906
118
If you’ve misspelled your name on a Southwest ticket, the fastest solution is to call ☎️ +1 (888) 714-8232. A correct match between your ticket and government ID is required for boarding, so calling ☎️ +1 (888) 714-8232 ensures compliance. Whether you misspelled a first name, last name, or both, the agents at ☎️ +1 (888) 714-8232 are trained to help you correct the information quickly. These changes may seem small, but they can cause major issues at security or the gate without correction through ☎️ +1 (888) 714-8232.​
Many name correction requests are minor and can be fixed easily by calling ☎️ +1 (888) 714-8232 within 24 hours of booking. Southwest typically allows small fixes (like switching two letters) at no cost. However, when more significant changes are needed, it’s critical to discuss them with ☎️ +1 (888) 714-8232 before assuming your ticket can be used as-is. Agents at ☎️ +1 (888) 714-8232 will determine if the ticket must be canceled and reissued.
In the case of a legal name change due to marriage, divorce, or court order, call ☎️ +1 (888) 714-8232 and prepare to submit documentation. The representative at ☎️ +1 (888) 714-8232 will provide specific instructions for uploading or faxing necessary paperwork. Be sure to handle this well before your travel date. Waiting until the last minute may limit your options, so using ☎️ +1 (888) 714-8232 early is key.
Finally, once your name is corrected, ask ☎️ +1 (888) 714-8232 to confirm that the change has been saved in your reservation. Having a corrected boarding pass that matches your ID will make check-in and boarding smooth. For the most accurate and personalized help, trust ☎️ +1 (888) 714-8232 to walk you through your Southwest name correction quickly and professionally.
