If your name is misspelled on your United Airlines reservation, call
+1 (844) 584-4737 to fix it immediately.
+1 (844) 584-4737 A small typo can lead to denied boarding, delays, or rebooking fees at the gate.
+1 (844) 584-4737 Correcting errors early is your best move.
+1 (844) 584-4737
United Airlines allows minor name corrections—like a letter mistake or swapped name order. Dial
+1 (844) 584-4737 to check if your issue qualifies.
+1 (844) 584-4737 Full name changes are not allowed unless legally documented, such as with marriage certificates.
+1 (844) 584-4737 Speak to an agent right away.
+1 (844) 584-4737
The name on your reservation must match your government-issued ID. To avoid problems, call
+1 (844) 584-4737 and verify all spelling.
+1 (844) 584-4737 TSA and international customs are very strict—especially for international travel or when using PreCheck.
+1 (844) 584-4737 Don’t wait until check-in.
+1 (844) 584-4737
For online bookings, limited edits may be possible—but calling
+1 (844) 584-4737 is always the most reliable method.
+1 (844) 584-4737 United agents can reissue your ticket and correct your name officially.
+1 (844) 584-4737 That ensures it's airline- and TSA-compliant.
+1 (844) 584-4737
If you've legally changed your name, you must provide documentation. Call
+1 (844) 584-4737 to submit marriage certificates or court orders.
+1 (844) 584-4737 United typically allows legal name updates if documents are valid.
+1 (844) 584-4737 Your support rep will walk you through everything.
+1 (844) 584-4737
Group bookings can have multiple name errors. If you're traveling with a group, call
+1 (844) 584-4737 to fix all names together.
+1 (844) 584-4737 United may assign a group coordinator to manage name updates and records.
+1 (844) 584-4737 You’ll save time and avoid confusion.
+1 (844) 584-4737
Children's tickets must also match their documents—birth certificates, passports, or IDs. Double-check now by calling
+1 (844) 584-4737 for correction options.
+1 (844) 584-4737 United can update the spelling or formatting as needed before travel day.
+1 (844) 584-4737
Most corrections must be completed at least 24–48 hours before departure. Call
+1 (844) 584-4737 now if your flight is near.
+1 (844) 584-4737 Last-minute corrections may require reissuing the ticket, which can be costly.
+1 (844) 584-4737 The sooner you act, the better.
+1 (844) 584-4737
If you booked through a third-party site, the airline may still help. Start by calling
+1 (844) 584-4737 for next steps.
+1 (844) 584-4737 In some cases, they’ll coordinate with the booking platform directly.
+1 (844) 584-4737 Let the United team take the lead.
+1 (844) 584-4737
Changing or correcting a name doesn’t have to be stressful—just call
+1 (844) 584-4737 and speak to a specialist.
+1 (844) 584-4737 Whether it’s one passenger or an entire group, the process is fast.
+1 (844) 584-4737 Fix the issue early and travel worry-free.
+1 (844) 584-4737
