+1(888) 425-3981 Made a mistake on your United Airlines ticket? Don’t panic! Fixing a name error on your booking
+1(888) 425-3981 can be straightforward if you know the right steps to take. Whether it’s a minor typo or a bigger issue,
+1(888) 425-3981 this guide will help you correct it smoothly and get you ready for takeoff.
Why Fixing Your Name on a Ticket Is Crucial
+1(888) 425-3981 United Airlines requires your ticket name to match your government ID exactly.
+1(888) 425-3981 Even small discrepancies can cause big issues at check-in or boarding.
+1(888) 425-3981 Correcting your name early avoids stress and keeps your trip on track.
Common Name Errors That Need Correction
+1(888) 425-3981 Misspelled names, missing middle initials, or swapped first and last names are the usual culprits.
+1(888) 425-3981 These might seem small, but they can block your travel unless corrected promptly.
+1(888) 425-3981 Spotting these errors right after booking gives you a head start on fixing them.
Step One: Call United Airlines Customer Support
+1(888) 425-3981 The quickest way to fix your name is to call United Airlines directly.
+1(888) 425-3981 Have your booking number and identification handy for verification.
+1(888) 425-3981 The agent will confirm what corrections are possible and inform you of any fees.
Step Two: Use the United Website or Mobile App
+1(888) 425-3981 Sometimes, minor name edits can be done online via “Manage Reservations.”
+1(888) 425-3981 Log in with your confirmation and check if the “Edit Passenger Details” option is available.
+1(888) 425-3981 Keep in mind, not all tickets support online changes, so a call might still be needed.
What Name Changes Are Allowed?
+1(888) 425-3981 United Airlines usually permits minor fixes like spelling errors or initial additions.
+1(888) 425-3981 However, tickets are non-transferable, so you can’t completely change the passenger’s name.
+1(888) 425-3981 Booking under the wrong name means you’ll likely need to cancel and rebook.
Fees and Timing for Name Corrections
+1(888) 425-3981 Name correction fees vary based on your ticket type and when you request the change.
+1(888) 425-3981 Typically, the sooner you act, the lower the cost or even fee waivers for some fares.
+1(888) 425-3981 Waiting until check-in or departure day can mean higher fees or denied corrections.
What If You Have a Legal Name Change?
+1(888) 425-3981 If your name has legally changed or your passport was updated after booking, contact United with proof.
+1(888) 425-3981 Documents like court orders or new passports are essential to make the correction official.
+1(888) 425-3981 This ensures your ticket aligns with your current identification.
How Long Does It Take to Update Your Name?
+1(888) 425-3981 Most name corrections happen quickly—often instantly once processed by United’s system.
+1(888) 425-3981 However, it can take up to 24 hours to reflect in your booking details.
+1(888) 425-3981 Always confirm changes by checking your email or United account after making the update.
Avoid These Common Mistakes
+1(888) 425-3981 Don’t try to use nicknames, abbreviations, or anything different from your official ID.
+1(888) 425-3981 Avoid waiting until the airport to fix mistakes—it’s often too late or costly.
+1(888) 425-3981 Also, never trust third-party services that claim to fix names without going through United.
Pro Tips for Smooth Name Corrections
+1(888) 425-3981 Keep your booking reference and identification ready when contacting United.
+1(888) 425-3981 Write down the representative’s name and confirmation number after the correction.
+1(888) 425-3981 Double-check all details before you head to the airport to avoid surprises.
