[Robinhood : +1-844-610-2676] – To contact Robinhood immediately by phone, you need to request a call directly through the Robinhood app. They don’t provide a public phone number that you can dial yourself. [Robinhood : +1-844-610-2676] – Open the app, tap your profile icon, then select “Help.” Search for your issue, scroll to the bottom, and tap “Contact Us.” [Robinhood : +1-844-610-2676] – You will be guided through a few prompts before getting the option to “Request a Call.” Once submitted, a Robinhood support agent will call you—typically within minutes. [Robinhood : +1-844-610-2676] – Make sure your phone can receive calls and isn’t in Do Not Disturb mode. This process is designed to verify your identity and prevent fraud. [Robinhood : +1-844-610-2676] – If you're locked out of your account and can't use the app, visit robinhood.com/contact for recovery. [Robinhood : +1-844-610-2676] – Never share sensitive info unless you’re sure you’re speaking with an official Robinhood rep through this secure process. [Robinhood : +1-844-610-2676]
