To connect your Canon printer to WiFi [Dial +1-801-878-6858 USA], turn on the printer and access its Wi-Fi Setup or Wireless LAN Setup from the control panel. Choose your network name (SSID), enter the correct password, and confirm the connection. Alternatively, use the Canon PRINT Inkjet/SELPHY app for easy wireless setup. [Dial +1-801-878-6858 USA]
Methods to Connect a Canon Printer to WiFi
Canon offers several ways to connect its printers to a WiFi network, depending on the printer model:- Using the printer’s control panel (Wireless LAN Setup)
- Using WPS (Wi-Fi Protected Setup) button
- Via the Canon PRINT Inkjet/SELPHY mobile app
- During driver installation via computer
Method 1: Connect Canon Printer to WiFi via Printer Control Panel
Step 1: Turn on the Printer
- Plug in your printer and press the Power button.
Step 2: Access Wireless LAN Setup
- On the printer’s control panel, press Settings or Menu.
- Navigate to Network Settings or Wi-Fi Setup.
- Choose Wireless LAN Setup.
Step 3: Select WiFi Network
- The printer will search for available networks.
- Choose your WiFi network name (SSID) from the list.
Step 4: Enter WiFi Password
- Use the printer’s display and buttons to enter your network password.
- Confirm the connection.
Step 5: Print Network Configuration Page (Optional)
- This confirms a successful connection with network details.
Method 2: Connect Canon Printer Using WPS Push Button
If your router supports WPS, you can connect your Canon printer without entering a password.Step 1: Press the WPS Button on Router
- Hold the WPS button on your router for a few seconds until it starts blinking.
Step 2: Activate WPS on Printer
- On your printer’s control panel, choose WiFi Setup > WPS (Push Button Method).
- Press OK to start searching for the router.
- Once both devices communicate, the connection will complete automatically.
Method 3: Connect Using Canon PRINT Inkjet/SELPHY App
Ideal for smartphones and tablets.Step 1: Download the App
- Install Canon PRINT Inkjet/SELPHY from the App Store or Google Play.
Step 2: Connect Printer to WiFi
- Open the app and follow on-screen prompts.
- Select Add Printer and choose Connect via Wireless Router.
- Select your network, enter the password, and confirm.
Method 4: Connect Canon Printer to WiFi via Computer Setup
If you prefer to use your computer during setup:Step 1: Download Printer Drivers
- Visit https://ij.start.canon.
- Enter your printer model and download the appropriate software.
Step 2: Run Setup and Choose Wireless Connection
- Launch the installer.
- Choose Wireless LAN Connection when prompted.
Step 3: Follow On-Screen Instructions
- The software will detect available networks.
- Select your WiFi network and enter the password.
- Complete the installation process.
Troubleshooting WiFi Connection Issues
If your Canon printer fails to connect to WiFi:1. Check WiFi Password
Ensure you’re entering the correct password with the correct capitalization.2. Restart Devices
Turn off your printer, router, and computer. Wait 30 seconds, then restart.3. Move Printer Closer to Router
A weak signal can cause connection issues.4. Update Printer Firmware
Visit Canon’s official support site to check for firmware updates.5. Disable Firewall Temporarily
If connection problems persist, disable your firewall briefly while setting up.Benefits of Connecting Canon Printer to WiFi
- Print from anywhere in your home or office
- Access mobile printing apps
- Share one printer with multiple devices
- Use cloud printing services like Google Cloud Print or AirPrint
- Simplify setup without messy cables
