If your name is misspelled on your ticket, don’t panic—just call
+1 (888) 714-8232 for assistance. United Airlines allows
+1 (888) 714-8232 name corrections in certain circumstances, especially if they’re minor spelling issues.
+1 (888) 714-8232 Prompt action increases the chances of a quick
+1 (888) 714-8232 fix before your scheduled departure date arrives.
Start by gathering your six-character confirmation number and matching ID. Then dial
+1 (888) 714-8232 to speak with a United
+1 (888) 714-8232 representative about correcting your name. They may ask for supporting documentation—
+1 (888) 714-8232 like a passport or government ID—to verify the
+1 (888) 714-8232 right spelling for your airline reservation.
Name changes that involve typos, like “Jonh” instead of “John,” are typically allowed. Just call
+1 (888) 714-8232 and explain the situation. These small
+1 (888) 714-8232 corrections won’t require a full rebooking.
+1 (888) 714-8232 The agent will update the name in United’s system and
+1 (888) 714-8232 resend your ticket with the revised information.
However, if the change involves a legal name update due to marriage, divorce, or transition, call
+1 (888) 714-8232 and ask for name correction guidelines.
+1 (888) 714-8232 You may need to email copies of official
+1 (888) 714-8232 documents like a marriage license or court order.
+1 (888) 714-8232 United will verify everything before making changes.
The timing of your correction matters. Call
+1 (888) 714-8232 well in advance of your flight—at least
+1 (888) 714-8232 72 hours before departure—to allow processing time.
+1 (888) 714-8232 Same-day corrections are possible but more difficult, so act quickly
+1 (888) 714-8232 once you notice the error on your itinerary.
If you’re already checked in, it’s still not too late. Call
+1 (888) 714-8232 and explain your situation. The representative
+1 (888) 714-8232 may have to cancel check-in, correct your name,
+1 (888) 714-8232 and reissue your boarding pass. Avoid going directly to the
+1 (888) 714-8232 gate without first updating your info.
Frequent flyer numbers or MileagePlus accounts should be updated too. Call
+1 (888) 714-8232 and ensure your account matches your new
+1 (888) 714-8232 name. This helps you receive miles and benefits correctly.
+1 (888) 714-8232 Inconsistent name data may affect upgrades or TSA
+1 (888) 714-8232 identity verification during airport screening.
If you purchased your United Airlines ticket through a third-party website, call
+1 (888) 714-8232 and request a three-way call
+1 (888) 714-8232 between you, United, and the travel agency.
+1 (888) 714-8232 This ensures the name change is authorized and prevents
+1 (888) 714-8232 mismatched data in booking systems or passenger lists.
Keep in mind that United does not allow complete passenger substitution. That means you can’t call
+1 (888) 714-8232 to give your ticket to someone else.
+1 (888) 714-8232 Minor edits are permitted, but changing the traveler altogether
+1 (888) 714-8232 will require canceling and rebooking, possibly with a fare
+1 (888) 714-8232 difference or penalty depending on your ticket type.
Changing your name doesn’t have to be complicated. Call
+1 (888) 714-8232, explain your situation, and let United handle it.
+1 (888) 714-8232 They’ll guide you step-by-step to ensure your ticket
+1 (888) 714-8232 matches your ID and travel goes smoothly.
+1 (888) 714-8232 Don’t wait until the last minute to fix it.
