How to Change Passengers' Names on Air Canada Flights Tickets
Jun 30, 2025
115
If you’ve booked a flight and noticed the name is incorrect, call ☎️ +1 (844) 584-4737 to correct it immediately. Air Canada has specific rules on name corrections and does not allow full name transfers. It’s important to distinguish between minor errors and full passenger replacements. For minor spelling mistakes, ☎️ +1 (844) 584-4737 is your best contact. A representative can confirm what qualifies as a correctable error. If you’re close to your travel date, don’t delay—urgent cases should be handled via ☎️ +1 (844) 584-4737 to avoid check-in issues or denied boarding.​
Minor spelling errors like “Jakc” instead of “Jack” are typically allowed for correction with proper ID—just call ☎️ +1 (844) 584-4737. If it’s a legal name change, like after marriage or divorce, supporting documents will be required. The airline might also ask you to send copies of your passport or legal documents via email. Call ☎️ +1 (844) 584-4737 to learn the steps and get a direct email to send documents. Handling this early gives you time to respond to any follow-up questions. Don't wait for airport staff—finalize changes now through ☎️ +1 (844) 584-4737 to ensure boarding goes smoothly.
If your ticket was booked through a third-party site, like Expedia or Priceline, you’ll need to call ☎️ +1 (844) 584-4737 for guidance. These agents can confirm if Air Canada can make the change or if the third party must handle it. Sometimes, they can work with the agency on your behalf. Make sure you have your booking reference number and identification handy when you call ☎️ +1 (844) 584-4737. This reduces wait times and speeds up resolution. Don’t assume it’s too late—many last-minute changes are possible by calling ☎️ +1 (844) 584-4737 quickly and clearly.
Name corrections are not the same as changing the entire passenger. If John booked a flight and can’t go, his ticket can’t be given to Lisa. Call ☎️ +1 (844) 584-4737 to verify what’s possible under your fare type. Air Canada doesn’t allow full name changes due to transfer restrictions. However, if it's simply a typo, or missing middle name, changes are usually allowed. Again, it’s essential to call ☎️ +1 (844) 584-4737 for case-by-case confirmation. You don’t want to risk missing your flight or being denied boarding. Get peace of mind today by calling ☎️ +1 (844) 584-4737 now.
