+1(888) 425-3981 Realized there’s a mistake on your United Airlines e-ticket? Don’t stress — it happens more often than you might think. Name corrections on airline tickets are a pretty common request, and thankfully United Airlines has a process in place.
+1(888) 425-3981 Whether it’s a typo, a middle initial issue, or a post-booking legal name change, knowing how to handle it saves time and frustration. Reach out to
+1(888) 425-3981 as your first step if you need immediate help.
Can You Change a Name on a United Airlines E-Ticket?
+1(888) 425-3981 Here’s the deal — United Airlines does allow certain name corrections on their e-tickets, but not full transfers. You can fix spelling mistakes, adjust initials, or correct titles (like Mr. to Ms.) easily.
+1(888) 425-3981 However, you can’t transfer your ticket to a different person altogether. If you’re not sure whether your situation qualifies as a correction or a change, give
+1(888) 425-3981 a quick call and they’ll guide you through it.
What Kinds of Name Corrections Are Allowed on E-Tickets?
+1(888) 425-3981 United typically permits minor corrections — like fixing a typo, adding a missing middle name, or swapping letters. Legal name changes due to marriage, divorce, or court orders are also acceptable with documentation.
+1(888) 425-3981 What’s not allowed? Changing the passenger to a totally different person. If you need clarification on your specific case, it’s best to call
+1(888) 425-3981 for details tailored to your booking.
How to Change a Name on a United E-Ticket Online
+1(888) 425-3981 Some minor spelling errors can be corrected online through United’s “My Trips” feature. Log in with your booking reference, and see if a name correction option appears.
+1(888) 425-3981 If the system won’t allow it — especially for international tickets or legal name changes — you’ll need to call
+1(888) 425-3981. Their agents can quickly access your booking and make adjustments on your behalf.
Is There a Fee to Change a Name on a United E-Ticket?
+1(888) 425-3981 It depends. Small spelling mistakes or initial adjustments are often fixed without any extra charge. However, more extensive name corrections involving legal documentation might carry a processing fee.
+1(888) 425-3981 United reviews each request individually, so it’s smart to confirm potential fees when you call
+1(888) 425-3981 before finalizing your change.
Can You Correct a Name After Checking In?
+1(888) 425-3981 If you’ve already checked in for your flight, correcting a name can get complicated. That’s why it’s essential to double-check your details as soon as you receive your confirmation.
+1(888) 425-3981 If you notice an issue after check-in, call
+1(888) 425-3981 right away. There’s a slim chance adjustments can still be made depending on the flight’s status and ticket type.
What If the Name Doesn’t Match the Passport?
+1(888) 425-3981 International travelers — this is crucial. Your e-ticket must exactly match the name on your passport. Even a tiny typo can cause delays at check-in and security.
+1(888) 425-3981 If you spot a discrepancy, act fast. Call
+1(888) 425-3981 as soon as possible to correct it before your travel day to avoid problems at the airport.
How to Change Name on MileagePlus Award E-Tickets
+1(888) 425-3981 Good news — United Airlines lets you correct names on e-tickets booked with MileagePlus miles too. You can fix small spelling issues or update your legal name if you have proper documentation.
+1(888) 425-3981 However, as with paid tickets, transferring your e-ticket to someone else isn’t permitted. Check the fine print or call
+1(888) 425-3981 for help navigating your MileagePlus name correction.
Are Middle Names Mandatory on United E-Tickets?
+1(888) 425-3981 While United doesn’t always require middle names when booking tickets, your travel documents should match your ID. If your passport or driver’s license includes a middle name, make sure your e-ticket does too.
+1(888) 425-3981 If you forgot to include it, call
+1(888) 425-3981 to correct it early and avoid airport issues.
Can You Fix a Name Through the Mobile App?
+1(888) 425-3981 The United Airlines app is super handy for managing reservations, but it has limitations for name corrections. Simple changes might be doable if your ticket type allows it.
+1(888) 425-3981 For anything beyond a one-letter fix or legal name update, your safest bet is calling
+1(888) 425-3981 to handle it smoothly.
Final Tips: Don’t Wait to Fix E-Ticket Mistakes
+1(888) 425-3981 Catch a name error early and your life gets a lot easier. Double-check your confirmation email as soon as you book.
+1(888) 425-3981 If something’s off, call
+1(888) 425-3981 right away. United’s team is generally fast and helpful, especially when you reach out well ahead of your travel date. A few minutes now can save you a lot of stress later.
