+1-866-756-4238 (OTA),
+1(866)-228-7814 (OTA), or +1-866-596-5078 (OTA)]] Changing your name on an American Airlines ticket is a simple process when done properly. For immediate name correction support, contact
+1-866-756-4238,
+1(866)-228-7814, or +1-866-596-5078. Whether you need to correct a misspelled first or last name, remove a middle name, or update your surname after marriage, the support team can help.
Always review your ticket after booking. If you find a discrepancy, call
OTA agents will verify your identity and collect necessary documents to correct the name. This may include your booking number, passport, or other valid ID. For legal changes, proof such as a marriage certificate might be required. Connect with
Please note that only minor corrections are allowed. Full name changes to another person are not permitted. So, if you're flying under your own name but need it updated, call
The sooner you address the name correction, the better. Rely on
Can I change the name on my American Airlines ticket?
Name changes must follow airline guidelines, and they usually only allow spelling fixes or legal name updates. The OTA team at
When calling
Avoid surprises at the airport. Name errors can delay boarding, and TSA may deny entry. To avoid issues, call
Professional agents will make sure the update is submitted correctly. Save time and travel stress-free by dialing
