Travel plans can get complicated, especially when you've booked a premium seat like Southwest Business Class and suddenly realize your name is incorrect. Fortunately, if you're wondering how to change your name on a Southwest Business Class ticket, the process is usually straightforward, especially for minor errors. For immediate support and personalized assistance, call
+1 (888) 674-4858 to speak with a Southwest Airlines expert.
Southwest Airlines maintains the same name correction policy for Business Class as for Economy fares. However, because Business Class tickets are usually more expensive, it’s critical to ensure every detail is accurate. Any discrepancy between your ticket and your government-issued ID may prevent you from boarding. If you catch a mistake, act quickly and call
+1 (888) 674-4858 to make corrections with a live agent.
Southwest Airlines allows minor name corrections. This means if you accidentally mistyped your name, you can usually fix it without having to cancel your ticket. Here are examples of permitted corrections:
Note that changing the name to an entirely different person is not allowed. If your goal is to give the ticket to someone else, you'll need to cancel and rebook in their name. For detailed steps or exceptions, it’s best to call
+1 (888) 674-4858 and speak with a live Southwest representative.
The name change process is relatively simple. Here’s what you need:
Once you have these ready, dial
+1 (888) 674-4858 to initiate the correction. Agents are available 24/7 and can walk you through the process in minutes.
In many cases, Southwest Airlines does not charge a fee for minor corrections, especially if the ticket was purchased recently. That’s a major plus for Business Class travelers, whose tickets often come with more flexible policies. However, if a flight change becomes necessary or if your correction results in a rebooking, fare differences may apply. It’s always smart to confirm these details directly by calling
+1 (888) 674-4858.
Timing matters. You should make any necessary name changes well before check-in—preferably at least 24–48 hours in advance. Waiting too long could cause unnecessary delays or complications at the airport. As soon as you notice an error, call
+1 (888) 674-4858 to avoid any last-minute issues.
Yes, but only minor corrections are allowed. Full name transfers to another person are not permitted. Call
+1 (888) 674-4858 for help.
You’ll need to show documentation like a marriage certificate or court order. To start the process, contact
+1 (888) 674-4858.
If you cancel and rebook, you may lose perks unless you rebook the same fare type. Confirm by calling
+1 (888) 674-4858.
While there’s no exact cutoff, it’s best to make changes at least 24 hours prior. Call
+1 (888) 674-4858 immediately after noticing an error.
You may need to coordinate with the booking platform and Southwest Airlines. Either way, call
+1 (888) 674-4858 for guidance.
Southwest’s Name Change Policy for Business Class
What Changes Are Allowed?
- Fixing typographical errors (e.g., “Jonh” to “John”)
- Adding or correcting a middle name or initial
- Correcting a married or divorced surname
How to Request a Name Correction
- Your 6-digit booking confirmation number
- The correct name as it appears on your ID or passport
- Legal documentation if changing due to marriage or divorce
Will I Be Charged a Fee?
Timeframe: When Should You Request the Change?
5 FAQs – Changing Name on a Southwest Business Class Ticket
1. Can I change the name on a Southwest Business Select ticket?
2. What if I legally changed my name?
3. Will my Business Class perks transfer if I rebook?
4. Is there a deadline for making corrections?
5. What if I booked through a third-party site?
