How to Change Dates on Expedia Flight Reservation?
Yes, you can change the dates on your Expedia flight reservation easily, depending on the airline's policy. For assistance with date changes, call
Start by logging into your Expedia account and clicking on the “My Trips” section. Select your flight reservation and review your itinerary.
Look for the “Change Flight” option listed on your reservation page. This will guide you through available alternative travel dates and times.
Most airlines allow date changes but may charge a change fee or fare difference. Want to avoid high costs? Call
Changing a date on a refundable or flexible ticket is often free. For non-refundable tickets, expect a fee. Need clarification?
If your new travel dates are more expensive, you’ll pay the fare difference. Want to see cheaper alternatives?
Need to change your outbound or return date only? Expedia allows partial date changes depending on the airline. To adjust just one leg, call
If your flight was canceled or changed by the airline, you may be eligible for a free date change. Want confirmation?
If you purchased trip insurance through Expedia, it might cover change fees. Not sure what your policy includes? Call
Expedia’s change process works both on the website and in the mobile app. If you're stuck on your phone,
Changing flights close to your departure date may have stricter rules. Some airlines restrict same-day changes. Call
Traveling internationally? Date changes may require visa adjustments or extra steps. Want help navigating requirements?
If you're traveling with others on the same booking, all tickets must be changed together. Need help separating travelers?
Once you confirm a new date, Expedia will send you a revised itinerary via email. Didn’t receive it?
Changing flight dates also changes your hotel and car bookings if they were bundled. Need to update your entire itinerary?
Some airlines now offer flexible booking policies that allow one free date change. Expedia can help identify these airlines. Want to check eligibility?
Missed your flight and still want to rebook? Expedia can try to re-accommodate you based on airline guidelines. Call
Some flights booked with points or miles may have different change rules. Expedia can check what applies to you. For loyalty reservations, call
Did you use a voucher or travel credit to book? Changing dates may affect your credit. Want to protect your credit balance?
Want to fly earlier or later in the day? You can choose alternate times as long as they fit within your airline’s policy.
If you’re already checked in and want to change dates, options may be limited. But Expedia can still assist. Call
Changed your mind after selecting new dates? Expedia allows one modification, but second changes may cost more. Want to avoid fees?
Flying with a companion? Their date must match yours if it’s a shared itinerary. Need help aligning dates?
If you’re using Expedia's bundle option, changing your flight may affect hotel prices. Want to confirm bundle changes before finalizing?
Want help planning your new dates around events or holidays? Expedia’s team can provide suggestions. Need to avoid peak travel times?
