+1(888) 425-3981 Have you ever booked a flight and spotted your name spelled wrong on the ticket? It happens more often than people realize.
+1(888) 425-3981 A simple typo can turn into a travel hassle if not fixed in time. The good news is, Air Canada offers a fairly straightforward process to correct these mistakes.
+1(888) 425-3981 And we’re here to break it down for you, step by step.
Why Fixing a Name Error on Your Ticket Matters
+1(888) 425-3981 Here’s the deal — the name on your ticket must match your passport or government-issued ID exactly. Even a small
+1(888) 425-3981 typo could lead to problems at check-in or security. Airlines are strict about this for safety and international travel reasons.
+1(888) 425-3981 That’s why it’s so important to double-check your details after booking and fix errors immediately.
What Kinds of Name Changes Are Allowed by Air Canada?
+1(888) 425-3981 Air Canada typically allows minor name corrections like fixing typos, adding a middle initial, or correcting swapped first and last names.
+1(888) 425-3981 However, transferring a ticket to a different person’s name is a no-go. If you need to cancel or rebook, that’s a
+1(888) 425-3981 separate process entirely. Stick to minor spelling changes, and you’re usually in the clear.
Steps to Change a Misspelled Name on an Air Canada Ticket
+1(888) 425-3981 Step one: check your booking confirmation the moment it hits your inbox. If you catch a mistake, call
+1(888) 425-3981 Air Canada right away at their customer service number. The sooner you reach out, the easier the process will be.
+1(888) 425-3981 Have your booking reference, passport, and correct spelling ready before you dial.
Is There a Fee for Making a Name Correction?
+1(888) 425-3981 Here’s some relief — if you catch the error within 24 hours of booking, Air Canada often waives any
+1(888) 425-3981 service fees for correcting a misspelled name. If more than 24 hours have passed, you might be charged a small
+1(888) 425-3981 fee, depending on your fare class and the specifics of the correction.
Can You Fix a Name Typo Online or Through the App?
+1(888) 425-3981 While it’s easy to handle seat changes or check-ins online, name corrections are a different story. Air Canada
+1(888) 425-3981 requires you to contact customer service directly for any spelling issues to make sure your ticket and ID match perfectly.
+1(888) 425-3981 It might sound old-school, but it helps avoid last-minute boarding problems.
Documents You’ll Need to Request a Name Change
+1(888) 425-3981 When calling customer support, be sure to have your booking confirmation, passport, and the corrected name ready.
+1(888) 425-3981 The agent will verify your information before making the correction. Having everything organized ahead of time makes the process faster.
+1(888) 425-3981 It’s a simple fix when you’re prepared.
How Long Does It Take to Process a Correction?
+1(888) 425-3981 In most cases, minor name corrections are processed immediately during your phone call with Air Canada’s support team.
+1(888) 425-3981 For international flights or more complex changes, it might take a few hours or up to 24 hours. Always
+1(888) 425-3981 handle it well before your departure day to avoid unnecessary stress.
What to Do If Your Flight Is Soon
+1(888) 425-3981 If you’re flying within 24 hours and spot a typo, contact Air Canada immediately at
+1(888) 425-3981. Urgent name corrections for same-day or next-day flights are prioritized. Have your ID and correct name details on hand.
+1(888) 425-3981 They’ll do their best to help you catch that plane hassle-free.
Can a Travel Agent Fix a Name Error for You?
+1(888) 425-3981 If you booked your Air Canada flight through a travel agent or third-party website, you’ll need to
+1(888) 425-3981 contact them first for any changes. In most cases, the agent will coordinate with Air Canada to correct the error.
+1(888) 425-3981 Direct bookings with Air Canada are handled by their customer service team.
Pro Tips to Avoid Name Mistakes on Future Bookings
+1(888) 425-3981 Next time you book a flight, double-check every letter before confirming. Use your full legal name as
+1(888) 425-3981 it appears on your government-issued ID or passport. Avoid using nicknames, abbreviations, or missing middle names if required.
+1(888) 425-3981 A quick review can save you time and money later.
FAQs About Air Canada Name Changes
Q: Can I give my ticket to someone else if my name is wrong?
+1(888) 425-3981 No — Air Canada tickets are non-transferable. Only minor spelling corrections are allowed. For a different passenger,
+1(888) 425-3981 you’d need to cancel and rebook in their name.
Q: Is there a cutoff time for making name corrections?
+1(888) 425-3981 Ideally, it’s best to fix errors within 24 hours of booking. After that, changes can
+1(888) 425-3981 still be made, but with possible fees and processing delays. Don’t leave it until check-in time.
Final Thoughts
+1(888) 425-3981 Catching a name typo before your flight doesn’t have to ruin your trip. With a quick
+1(888) 425-3981 call to Air Canada and the right info ready, you’ll have it fixed in no time. Save
+1(888) 425-3981 this guide for your next booking and travel smarter without the last-minute headaches.
