how much tranny & rear end fluid for 7mgte
Idealsupra
Orlando
www.tampabaysupras.com
check the TSRM for sure.. however for the tranny fluid i believe its 3.4 qts...
another way to do it is keep the drain plug open and pour it into the shifter until it starts to leak out.... that works also...
Supra Blues
Virgin Booster
Supramania
Keep the drain plug open til it leaks out, then its full???
Do you mean the filler plug???
When the filler plug-hole leaks thats when its full.
americanjebus
Mr. Evergreen
wa.
anyone have a pic of the filler plug, on an auto. heh i just use the dipstick and measured ammount from owners manual
DrakeMK3
"The Duck"
Knoxville, TN
Those bastards at toyota measured it just so you have to buy the additional quart for .2 and .4 quarts.
If you can hear me Toyota...GO TO HELL!! Muahahaha!!
Seriously though, I don't even bother with the filler plug deal. I just take off the shifter and dump in the 3 quarts of fluid. Finally, I top it off by measuring the remaining .2 quarts. Easy as pie. Mmmm.......pie.......
Art Vandelay
Bonehead
Winston Salem, NC
There isn't a filler plug on the A340 auto trans, you use the transmission dipstick opening just as you descibed.
