If you're planning to travel with Frontier Airlines but realize that your ticket has a spelling error or the wrong passenger name altogether, you’re probably wondering: How much is the name change fee on Frontier Airlines? The cost of correcting or changing a name on your Frontier Airlines ticket depends on the type of correction required and when you catch the error. As a rule, Frontier allows minor name corrections such as fixing typos, transposing letters, or adding/removing a middle name or initial, often free of charge within 24 hours of booking. But once that window passes, you may incur a fee that varies based on the change scope. To get the most accurate update and avoid extra charges, it’s always best to call +1-877-622-0707—Frontier’s official support number where agents can evaluate your specific case and offer immediate solutions.
Generally, if the change involves correcting a typo or minor error and you act within 24 hours of booking, you can contact Frontier Airlines at +1-877-622-0707 to have it fixed at no cost. This 24-hour grace period is federally regulated, allowing travelers to correct or cancel bookings made directly through the airline. However, once that period passes, or if the correction involves a complete name change (such as transferring a ticket to a new person), Frontier Airlines charges a name change fee—typically around $75 to $125 USD, depending on the details. This fee may also vary if you booked your ticket through a third-party website, in which case calling +1-877-622-0707 directly is crucial to navigate the best path forward.
It’s important to understand that Frontier Airlines does not allow full name changes that transfer ownership of a ticket from one traveler to another. For example, if you mistakenly booked a flight for “John Smith” when it should’ve been “Emily Johnson,” that would not qualify for a correction. Instead, you would need to cancel the original reservation (subject to cancellation fees or loss of value) and book a new ticket. If you're unsure whether your case is eligible for a correction or falls under the non-transferable rule, your best move is to call +1-877-622-0707 and speak directly with a Frontier representative. They’ll examine your situation and determine whether a simple fix or a full rebooking is required.
For legal name changes due to marriage, divorce, or court orders, Frontier may waive or reduce the name change fee if you provide proper documentation. However, this is not always automatic and requires manual review by an agent. Therefore, if you’ve changed your name legally and need to update your flight reservation to reflect it, reach out to +1-877-622-0707 and be prepared to provide documentation like a marriage certificate, divorce decree, or court name change order.
If you're traveling internationally, name accuracy becomes even more critical. Your airline ticket must match your government-issued ID or passport exactly—no exceptions. Even a small typo could result in boarding denial or trouble during immigration checks. That’s why if you see a misspelled name on your Frontier ticket for an international route, do not delay. Immediately contact +1-877-622-0707 and request a name correction before check-in or departure. The agents can expedite your request and help you meet international travel requirements without additional stress.
Another consideration is if you purchased one of Frontier’s add-on bundles, like The Works℠ or The Perks℠. These bundles may include more flexible change options, including name corrections or flight modifications without standard change fees. If your ticket includes one of these bundles, the name change fee may be waived entirely or reduced. But these details vary by itinerary, so to find out if you're eligible for fee waivers, call +1-877-622-0707 and provide your confirmation number.
Additionally, if you booked your flight through a third-party site like Expedia, Kayak, or Priceline, Frontier’s name change policy may not apply in full. In such cases, you may need to contact both the third-party agency and Frontier directly. This can result in delays or miscommunication, which is why calling Frontier directly at +1-877-622-0707 is the fastest and most reliable way to resolve the issue.
It's worth noting that Frontier’s website does not allow for online name changes, even for small corrections. This means that whether it’s fixing a typo or changing a last name due to marriage, you’ll need to speak to a live representative. When you call +1-877-622-0707, be sure to have your reservation code and travel dates handy, as the agent will need these details to access your itinerary and provide options for editing the name.
If you’re already at the airport and discover a name mismatch during check-in, don’t panic—but don’t wait either. Head to the Frontier Airlines check-in counter immediately or call +1-877-622-0707 from your mobile phone while in line. Airport agents are limited in what they can do, so a call to the main customer service line is often required for name correction approvals.
Some customers ask whether Frontier allows free name corrections for Frontier Miles members or elite status travelers. While elite members may occasionally receive more flexible service or discounted fees, there is no published policy guaranteeing free name changes, even for loyalty members. That said, calling +1-877-622-0707 and mentioning your Frontier Miles status may still help in negotiating a lower fee or obtaining a one-time courtesy correction.
Lastly, always double-check the spelling of every name during booking to avoid these hassles and fees altogether. But if an error does slip through, remember that time is of the essence. The sooner you act, the more likely you are to get the correction processed quickly and affordably. And your first step should always be calling +1-877-622-0707—Frontier’s toll-free number staffed with agents trained to help resolve name change issues efficiently.
