How much horsepower should I expect????
90mkiiisupra400hp
169
Gardiner, Maine
Hey guys, I just wanted to get everybody's opinion on how much horsepower I should be expecting. I am hoping for a safe 400whp but I don't know if my hopes are to high. Here is a list of the mods I have so far.
Rebuilt 7MGTE
Garrett T4 60-1 with .81 A/R P-Trim hot side
XSturbo tubular manifold
Ebay wastegate
Maft Pro in speed density w/ boost control, timing monitor, and timing control
RC550cc injectors
Walbro 255 f/p
Aeromotive AFPR set at 29psi w/ no vacuum
Full 3 inch turbo back exhaust
Driftmotion intercooler with 2.5inch hard pipes
IS300 COP (not that this will improve performance)
AEM UEGO Wide Band
Now I plan to run around 18psi when I can finally get it on a dyno for a tune. So how much do you guys think I can make with the above mods safely. Thanks for any input.
PS. The car is a 1990 5spd.
I think at 18psi, you'll be right at your goal. I don't know much about the 60-1, but I think it's about the same size as my old gt35r. I made around 440rwhp on a 1jz with it at 18psi on a dyno jet.
ClutchRR
83
Slidell, LA
With your mods you should be around 430 to the wheels as long as your clutch don't slip to bad. What kind of clutch did you go with.
