+1(888) 425-3981 Got a typo or name issue on your Air Canada ticket? You're definitely not alone. Whether it’s a small spelling error or a legal name change, figuring out the cost to fix it is crucial before your travel date.
+1(888) 425-3981 The good news is that Air Canada
does allow name corrections, but there are rules—and sometimes, fees.
+1(888) 425-3981 This guide breaks down everything you need to know, in plain English, no guesswork required.
Why Getting Your Name Right on the Ticket Matters
+1(888) 425-3981 Let’s get one thing straight: your name must match your ID
exactly to board your flight.
+1(888) 425-3981 A small typo can cause big delays at the airport, or even keep you from flying.
+1(888) 425-3981 That’s why correcting it early is so important—and yes, it might come with a fee.
The Short Answer: How Much Does It Cost?
+1(888) 425-3981 Air Canada typically charges between
$60 and $150 to change a name on a ticket.
+1(888) 425-3981 The final cost depends on your fare class, how you booked, and how close you are to departure.
+1(888) 425-3981 Here’s how it breaks down so you’re not caught off guard.
- Basic Economy or Promo Fares – Often non-changeable
- Standard & Flex Fares – May allow changes with a fee ($100–$150)
- Premium Fares – Lower or no fee for minor corrections
What Kind of Name Changes Are Allowed?
+1(888) 425-3981 Not all name changes are treated the same, and that affects the cost.
+1(888) 425-3981 Air Canada typically allows minor name
corrections, not full ticket transfers to another person.
+1(888) 425-3981 Here's what usually qualifies:
- Fixing a typo or spelling error (e.g., "Jhon" to "John")
- Adding/removing middle names or initials
- Correcting a legal name due to marriage, divorce, or other documentation
When You Might Not Be Charged
+1(888) 425-3981 If it's a very small correction (like a one-letter fix), you may avoid a fee altogether.
+1(888) 425-3981 But this is often subject to how early you catch the mistake and the fare you purchased.
+1(888) 425-3981 Always double-check with an agent before assuming it’s free.
The Best Way to Make a Name Change on Air Canada
+1(888) 425-3981 The fastest and most reliable way to correct a name is by calling customer service directly.
+1(888) 425-3981 An agent can walk you through the steps and tell you if your correction qualifies and what it costs.
+1(888) 425-3981 You can also check the “Manage My Bookings” section online for small changes.
What You’ll Need to Make the Change
+1(888) 425-3981 To update the name on your ticket, have the following ready before you call or go online.
+1(888) 425-3981 Being prepared will save you time and might even help reduce your fee.
+1(888) 425-3981
- Your six-digit booking reference
- Passport or government-issued ID
- Proof of name change (if applicable)
- Original booking info or payment receipt
How Timing Affects the Name Change Fee
+1(888) 425-3981 The closer your flight date, the higher the chance of fees or limitations on changes.
+1(888) 425-3981 That’s why we recommend correcting any issues as soon as you catch them—ideally within 24 hours.
+1(888) 425-3981 In some cases, changes made within that first day may even be free.
Booked Through a Travel Agent or Third-Party Site?
+1(888) 425-3981 If you didn’t book directly through Air Canada, things can get a bit trickier.
+1(888) 425-3981 Third-party sites may have their own policies, and you’ll likely need to contact them first.
+1(888) 425-3981 Once they approve the change, Air Canada can process it—often with an added fee.
What About Aeroplan Bookings?
+1(888) 425-3981 For reward travel booked with Aeroplan points, rules may differ slightly.
+1(888) 425-3981 Minor corrections are usually allowed, but changing the passenger altogether isn’t an option.
+1(888) 425-3981 You may have to cancel and rebook using your points, so check before making moves.
Avoiding Name Change Fees in the Future
+1(888) 425-3981 Want to avoid fees and stress down the road? Do a double-check before hitting “confirm.”
+1(888) 425-3981 Make sure names exactly match what's listed on your passport or official ID.
+1(888) 425-3981 Especially when booking for someone else, don’t assume—you need the correct legal name.
Real Stories: What Travelers Say About the Experience
+1(888) 425-3981 Many travelers report a smooth experience when calling Air Canada to correct small errors.
+1(888) 425-3981 As long as you catch the issue early, reps are usually helpful and transparent about fees.
+1(888) 425-3981 That said, high volumes during peak seasons can cause some delays, so plan ahead.
Quick Name Change Checklist
+1(888) 425-3981 Before you reach out to Air Canada, use this checklist to make the process faster and easier.
+1(888) 425-3981 Having everything ready could even help lower the name change fee in some cases.
+1(888) 425-3981
Booking reference or confirmation code
Correct spelling of the name
Copy of passport or government ID
Legal documents (if applicable)
Payment method for any applicable fees
Final Thoughts: Don’t Let a Name Error Ground Your Plans
+1(888) 425-3981 A name issue on your flight ticket doesn’t have to ruin your travel experience.
+1(888) 425-3981 With clear policies and helpful support, Air Canada gives you options to fix things fast.
+1(888) 425-3981 Just remember—act early, have your info ready, and know your fare rules.
Need Help Now? Talk to a Real Person
+1(888) 425-3981 Still unsure what your name change will cost? Call Air Canada support and speak with a rep.
+1(888) 425-3981 They'll help you understand your fare type, eligibility, and any applicable fees.
+1(888) 425-3981 Getting answers straight from the source is always the best move.
