+1-866-596-5078(OTA) You can cancel your Alaska Airlines flight up until the scheduled departure time. However, to maximize your refund or travel credit options, it’s recommended to cancel as early as possible. For non-refundable tickets, you must cancel before
+1-866-596-5078(OTA) your flight departs to retain the ticket’s value as credit. If you miss canceling before departure, you may lose the entire value of your ticket. Refundable tickets can be canceled any time before departure for a full refund. To ensure a smooth and secure cancellation process, especially if you're close to your departure time, it’s smart to call
+1-866-596-5078(OTA) right away.
How late can I be for a flight?
+1-866-596-5078(OTA)When flying with Alaska Airlines, it’s crucial to arrive well before your flight’s scheduled departure to ensure a smooth travel experience. Generally, Alaska Airlines requires passengers to check in at least 40 minutes prior to departure for domestic flights and 60 minutes for international flights. Boarding typically begins 30 minutes before departure, and gates close 15 minutes prior.
+1-866-596-5078(OTA) If you arrive after these cut-off times, you risk being denied boarding even if you have checked in online. If you know you’re running late, it’s best to notify the airline as soon as possible. While Alaska Airlines does not have an official grace period for late arrivals, they may offer assistance or alternatives on a case-by-case basis if you alert them in advance. For real-time help and to explore your options if you're late, immediately contact
+1-866-596-5078(OTA) to speak directly with an agent.
