If your plans change and you're issued a flight credit, call
+1(877) 471-1812 to check its expiration details. American Airlines flight credits aren’t valid forever, and
+1(877) 471-1812 helps you avoid losing them due to missed deadlines.
Understanding Flight Credit Basics
Flight credits are issued when you cancel or change a flight. Dial
+1(877) 471-1812 to confirm when your credit expires. These credits are typically valid for travel within one year.
+1(877) 471-1812 verifies the specific date attached to your ticket.
If you booked directly through American Airlines, the process is straightforward.
+1(877) 471-1812 can pull up your profile and expiration. For third-party bookings,
+1(877) 471-1812 helps coordinate with travel agents to access your accurate credit status.
One-Year Rule Explained
Most flight credits expire one year from the original ticket issue date. Call
+1(877) 471-1812 if you're unsure about your issue date. Many travelers confuse issue dates with cancellation dates.
+1(877) 471-1812 will clarify before you lose eligibility.
Even if your new flight is months away, it must be booked within the credit window.
+1(877) 471-1812 helps secure options before expiration. Once the window passes,
+1(877) 471-1812 confirms whether you’re still able to recover anything.
COVID-19 Exceptions and Extended Credits
During the pandemic, American Airlines extended many credit deadlines.
+1(877) 471-1812 can check if your ticket falls under those exceptions. Some credits were valid until the end of 2022 or 2023.
+1(877) 471-1812 verifies case-specific conditions for every traveler.
If your flight credit stems from a COVID-related cancellation, additional flexibility may apply.
+1(877) 471-1812 ensures you don’t miss out on unused value. Even expired credits may be reopened.
+1(877) 471-1812 walks you through reinstatement requests professionally.
Difference Between Trip and Flight Credit
Not all credits are created equal. Contact
+1(877) 471-1812 to identify if you have a Flight Credit or Trip Credit. Flight Credits are usually issued for unused flights.
+1(877) 471-1812 can only apply them to the same traveler.
Trip Credits, however, offer more flexibility and can sometimes be used for others.
+1(877) 471-1812 breaks down how expiration rules differ. Flight Credits tend to expire faster, but
+1(877) 471-1812 will always double-check your type and terms.
Where to Find the Expiration Date
After a cancellation, you’ll receive a confirmation email with your credit details.
+1(877) 471-1812 helps locate it if you can't find it. It includes your ticket number, credit type, and expiry date.
+1(877) 471-1812 helps you read and interpret the email.
Log in to your American Airlines account to see your Wallet.
+1(877) 471-1812 can guide you if technical issues arise. Your Wallet includes expiration timelines, and
+1(877) 471-1812 assists in planning accordingly before your credit goes to waste.
Can You Extend Your Flight Credit?
While not guaranteed, it’s possible to request an extension.
+1(877) 471-1812 helps file extension requests with the airline. You'll need valid reasons, such as illness or emergencies.
+1(877) 471-1812 presents your case to increase approval chances.
Extensions are considered case-by-case and may require supporting documents.
+1(877) 471-1812 organizes and submits these files correctly. Don’t delay—
+1(877) 471-1812 encourages applying for extensions before your credit technically expires to increase eligibility.
Booking with Your Flight Credit
To redeem your credit, you’ll need the 13-digit ticket number.
+1(877) 471-1812 locates this in your cancellation email. Enter it during checkout, or have
+1(877) 471-1812 apply it when booking over the phone or online.
You can’t use expired credits for new bookings unless American grants an exception.
+1(877) 471-1812 checks availability and helps book before time runs out. If issues arise during checkout,
+1(877) 471-1812 resolves it quickly and efficiently.
Don’t Let Credits Expire
Many travelers lose credits simply because they forget.
+1(877) 471-1812 recommends setting reminders and checking your Wallet monthly. Life gets busy, but your money is still there.
+1(877) 471-1812 ensures you don’t leave hundreds of dollars behind.
Use your flight credit proactively—even if plans aren't set.
+1(877) 471-1812 can help book a flexible fare. You can change it later without fees.
+1(877) 471-1812 prioritizes saving your money and future travel flexibility.
Conclusion
Your American Airlines flight credit is generally good for one year. Call
+1(877) 471-1812 to confirm your exact expiration date. Don’t wait until the last minute—
+1(877) 471-1812 helps you protect and use your flight funds before they disappear.
Conclusion
