how exactly do...
TooGoode
rediculous DD
Mar 1, 2007
549
Chandler, Arizona
i take out my gauges without taking out my dash? i just bought some new white gauge faces from ebay and want to know how to tak the cluster out without taking the dash out. is it hard to do? how long would it take?
Shytheed Dumas
For Sale
Mar 6, 2006
967
Louisville, KY
Try this:
5 minutes tops.
:naughty:
OneJoeZee
Retired Post Whore
aboard the Argama
It is very easy to take out the gauge cluster. Just take out the top plastic part. Then there is some screws holding the cluster to the dash. You will see them easy. Take the screws out. Unplug the connectors from the back of the dash and pull the cluster.
Should not take you anymore than 10 minutes at most.
americanjebus
Mr. Evergreen
wa.
Get a phillips and a flathead and remove the following.
Plastic cover over shifter/climate control, i had to remove plastic around steering wheel, fog light switch panel, plastic cover over gauge cluster. then like 6? screws holding cluster in. ::ignore glove box::
took me like an hour because i had to find each screw 1 at a time.
