How does SAFCII stores settings in the memory...?
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
I've been trying to figure out exactly how SAFC stores Hi and Lo throttle adjustments in its memory.
When you set NEpoints its allows you to adjust the % at that point and adjusts the points around it, for instance:
Assume Lo-throttle set @30%
If your first NEpoint is 2800RPM, and the next is 3000RPM, the adjustment made at 2800 lets say is 10%, 10% will now be automatically set at all RPM points before 2800RPM.
Now, lets say you kept you 10% but then adjusted your first NE point to 2400RPM and set the new NEpoint to 5%, will it change the 10% at lets 2600RPM?
Now here's where I really get messed up. Lets say you change your Lo-throttle point to 15%, and changed adjusted the 2400RPM point (or any point) to 12%, will SAFCII remember to keep the 5% adjustment if the throttle is pressed to 30%?
Thanks for any clarification you can provide. I ask this question because i've noticed adjustment values at certain RPM/throttle points i currently dont have set for, for either hi or lo throttle points.
