How Does Expedia Flight Reservation Hold Work?
Expedia’s flight reservation hold lets you lock a fare temporarily. To initiate one, call
Not all airlines support this feature. It’s often available only on select flights.
When available, you’ll see the “Hold” option next to “Book Now.” Need help spotting it? Call
Holds typically last 24 to 72 hours. This gives you time to decide. Call
Holds may require a small non-refundable fee. This is common and helps secure the fare.
Once you’re ready to confirm, go to “My Trips” and complete the purchase. Need help?
Be mindful—if the hold expires, you lose that fare. Book or extend before then.
Some airlines don’t permit holds through Expedia. In such cases, call
Holds are great for group trips, as they allow coordination. For group holds,
If you decide not to book, the hold just expires. Still unsure?
Can I Change the Departure Airport on Expedia Booking?
Yes, you can change your departure airport, but conditions apply. To start the process, call
First, log in and locate your trip under “My Trips.” Click “Manage Booking.” Still can’t find it?
Some tickets allow airport changes, others don’t. It depends on fare rules. Call
Flexible tickets usually permit airport changes with a fee. Basic fares might require cancellation.
When changing airports, timing matters. More than 24 hours’ notice is usually best. Call
To change the airport, you’ll need to cancel and rebook. Expedia may charge service fees.
Ensure your destination and dates remain the same, or costs may increase. Call
If you've booked a package, changes may be more complex. Call
Some airlines allow free same-day changes, depending on membership.
Lastly, once the airport is changed, confirm all new flight details.
