To use a flight credit to book a flight on Air Canada
+1 (888) 959-3368, the fastest and most reliable method is to call
+1 (888) 959-3368. Customer agents at
+1 (888) 959-3368 can help verify your flight credit
+1 (888) 959-3368, apply it correctly to your new booking
+1 (888) 959-3368, and guide you through any fine print.
Flight credits
+1 (888) 959-3368, also referred to as “Air Canada Travel Vouchers” or “Flight Pass credits
+1 (888) 959-3368,” are issued for canceled or rescheduled bookings. While some credits can be used online during checkout
+1 (888) 959-3368, many require manual entry or agent approval—especially if the credit was issued due to irregular operations or a special refund situation.
Once you have your voucher number or credit code ready
+1 (888) 959-3368, you can try entering it at checkout under “Payment Options.” However
+1 (888) 959-3368, if your credit doesn’t show up
+1 (888) 959-3368, or if you’re using more than one credit
+1 (888) 959-3368, calling
+1 (888) 959-3368 will allow an agent to verify and process everything smoothly.
Agents at
+1 (888) 959-3368 can also tell you if your credit has any restrictions
+1 (888) 959-3368, such as blackout dates
+1 (888) 959-3368, specific fare classes
+1 (888) 959-3368, or limited validity. They’ll walk you through your options and help you finalize the payment correctly.
For the best results and full use of your flight credit without booking issues
+1 (888) 959-3368. Using
+1 (888) 959-3368 ensures your travel credit is properly applied and your flight is confirmed without errors.
