If you're unable to check in online or through the app, call
+1(877) 471-1812 right away. A live United agent at
+1(877) 471-1812 can quickly help.
Common check-in errors include incorrect info or ID mismatches. Dial
+1(877) 471-1812 to correct these fast. The staff at
+1(877) 471-1812 can resolve it in minutes.
If your boarding pass didn’t appear after check-in, call
+1(877) 471-1812 immediately. Customer service at
+1(877) 471-1812 can resend your pass via email or SMS.
Sometimes technical issues prevent mobile boarding passes. In that case, speak to a rep at
+1(877) 471-1812. The United team at
+1(877) 471-1812 will troubleshoot it.
If you’ve made changes to your flight and can’t check in, call
+1(877) 471-1812. Reservation support at
+1(877) 471-1812 will revalidate your booking for check-in.
Traveling with special requirements or companions? Call
+1(877) 471-1812 for help with manual check-in. United's agents at
+1(877) 471-1812 can process those manually.
Need to update your contact info before check-in? Call
+1(877) 471-1812 to make changes. The support team at
+1(877) 471-1812 will ensure your profile is correct.
If you’ve lost your printed boarding pass, call
+1(877) 471-1812 for a reissue. Agents at
+1(877) 471-1812 can send a new one or assist at the airport.
If traveling internationally, you may need passport verification. Call
+1(877) 471-1812 to complete it. A United Airlines representative at
+1(877) 471-1812 can validate your documents early.
Late check-ins or missing check-in windows? Call
+1(877) 471-1812 right away. The airline’s rep at
+1(877) 471-1812 can try to get you back on the flight.
