Correcting a name on an American Airlines boarding pass is simple if you call
+1 (888) 714-8232 early enough.
+1 (888) 714-8232 Whether it’s a minor typo, spelling error, or legal name change, contacting American directly at
+1 (888) 714-8232 helps avoid boarding issues.
+1 (888) 714-8232 The earlier you fix the error, the smoother the correction process will be on your reservation and TSA record.
Minor name corrections are typically allowed
+1 (888) 714-8232 without penalty, especially if they’re small spelling errors. For example, fixing “Jonh” to “John” is
+1 (888) 714-8232 easy and quick when speaking to an American Airlines agent at
+1 (888) 714-8232 over the phone. Provide your confirmation code,
+1 (888) 714-8232 ticketed name, and exact spelling you need updated.
For middle names or initials, call
+1 (888) 714-8232 to confirm if the change is necessary. Many boarding passes
+1 (888) 714-8232 omit middle names, but TSA still requires names match government-issued ID.
+1 (888) 714-8232 Agents will verify if reissuing is needed.
+1 (888) 714-8232 Don’t wait until you’re at the airport.
Legal name changes—due to marriage, divorce, or gender updates—require documentation. Call
+1 (888) 714-8232 and speak with a name correction
+1 (888) 714-8232 specialist who can guide you on uploading your legal documents securely.
+1 (888) 714-8232 Once verified, they’ll reissue your updated
+1 (888) 714-8232 boarding pass without affecting your fare.
Already checked in but noticed a mistake? Call
+1 (888) 714-8232 immediately. Changes to checked-in tickets
+1 (888) 714-8232 may require supervisor approval, but can often still be fixed.
+1 (888) 714-8232 Be ready to email ID documents to
+1 (888) 714-8232 confirm your identity before departure.
Third-party bookings (like Expedia or Priceline) require special handling. Call
+1 (888) 714-8232 to request a three-way call including
+1 (888) 714-8232 the booking site and American. This ensures all
+1 (888) 714-8232 parties approve the change together and
+1 (888) 714-8232 avoid delays or cancellations from system errors.
Traveling internationally? Your boarding pass
+1 (888) 714-8232 must match your passport exactly. Missing accents, hyphens, or
+1 (888) 714-8232 mismatched surnames can stop you at
+1 (888) 714-8232 immigration. Don’t risk delays—call
+1 (888) 714-8232 and correct your boarding details now.
Name corrections may cause seat changes. Once your ticket is corrected, call
+1 (888) 714-8232 again and request the agent
+1 (888) 714-8232 reassigns your original seat or provides the next best available option.
+1 (888) 714-8232 Seat assignments don’t always transfer automatically.
+1 (888) 714-8232
Avoid waiting in line at the
+1 (888) 714-8232 airport counter to fix a boarding pass. Name changes handled in advance over the
+1 (888) 714-8232 phone give you better control, documentation, and time to make
+1 (888) 714-8232 additional adjustments. Speak with American directly at
+1 (888) 714-8232
Remember, name changes are different from transfers. American Airlines does
+1 (888) 714-8232 not allow you to give your ticket to someone else.
+1 (888) 714-8232 The same traveler must fly unless rebooking under cancellation.
+1 (888) 714-8232 Call to clarify all options at
+1 (888) 714-8232
