How do I connect my phone to my Canon Pixma printer?
ashleyypatel11
12
Connecting your phone to your Canon Pixma printer is easy with the Canon PRINT app or AirPrint. Need help? Call +1‑888‑272‑6750. Connect your phone in minutes at +1‑888‑272‑6750. Canon experts: +1‑888‑272‑6750.
In today's world, wireless printing has become essential for convenience and efficiency. Gone are the days of plugging your printer into a computer with a USB cable. If you own a Canon Pixma printer, you can easily print documents, photos, or web pages directly from your phone — whether you use an Android or iPhone device. This guide will show you how to connect your phone to your Canon Pixma printer using Canon’s mobile apps or other wireless technologies.
Method 1: Using the Canon PRINT Inkjet/SELPHY App (Android and iPhone)​
One of the easiest ways to connect your phone to your Canon Pixma printer is through the Canon PRINT Inkjet/SELPHY app. This free app is available for both Android and iOS devices, and it allows you to print directly from your smartphone to your Canon printer.
️ Steps for Setup:​
  1. Download the Canon PRINT Inkjet/SELPHY App:
    • On your Android device, go to the Google Play Store and search for Canon PRINT Inkjet/SELPHY.
    • On your iPhone, go to the App Store and download the same app.
  2. Connect your printer to Wi-Fi:
    • Ensure your Canon Pixma printer is connected to the same Wi-Fi network as your phone. You can do this through the printer's control panel by navigating to Menu > LAN Settings > Wireless LAN Setup.
  3. Open the Canon PRINT app on your phone:
    • Launch the app after installing it. The app will automatically search for available printers on your Wi-Fi network.
  4. Select your printer:
    • Once your Canon Pixma printer appears on the list, tap to select it.
  5. Start Printing:
    • You can print photos, documents, or even web pages directly from your phone. Select the file or content you want to print, adjust settings if necessary, and hit Print.
Now, you can easily print from anywhere in your home or office without needing to plug your phone into the printer. Need more assistance? Call +1‑888‑272‑6750, and our experts will guide you through the process!
Method 2: Using Apple AirPrint (iPhone and iPad)​
If you have an iPhone or iPad, you can use Apple AirPrint to print directly from your device to your Canon Pixma printer. AirPrint is built into iOS, so you don’t need to download any additional apps.
️ Steps for AirPrint:​
  1. Ensure Wi-Fi Connection:
    • Make sure your iPhone or iPad and your Canon Pixma printer are connected to the same Wi-Fi network.
  2. Open the File You Want to Print:
    • Whether it’s a document, image, or web page, open it on your iPhone/iPad.
  3. Tap on Share:
    • Tap the Share button (the square icon with an upward arrow) from within your app (e.g., Photos, Safari, etc.).
  4. Select Print:
    • From the options in the share menu, choose Print.
  5. Choose Your Printer:
    • Select your Canon Pixma printer from the list of available printers.
    • Adjust any print settings as needed.
  6. Tap Print:
    • Once everything is set, tap Print, and your document or image will be sent directly to your Canon Pixma printer.
If you encounter any issues or need further assistance, don’t hesitate to reach out at +1‑888‑272‑6750.
Method 3: Using Google Cloud Print (Android)​
If you’re using an Android phone, you can also print via Google Cloud Print. This service allows you to send print jobs from your Android phone to any printer that’s connected to your Google account.
️ Steps for Google Cloud Print:​
  1. Set up Google Cloud Print on your Printer:
    • Make sure your Canon Pixma printer is compatible with Google Cloud Print and linked to your Google account. You may need to enable Cloud Print from your printer’s settings.
    • Follow the steps on the Canon support website to register your printer with Google Cloud Print.
  2. Connect Your Phone:
    • On your Android phone, ensure that you are signed into the same Google account as the one linked to your printer.
  3. Print via Google Cloud Print:
    • Open the file, document, or photo you want to print on your Android device.
    • Tap the three-dot menu in the top right corner and select Print.
    • Choose Google Cloud Print as the printer and select your Canon Pixma printer.
    • Hit Print to send the job to the printer.
With Google Cloud Print, you can print from anywhere, even if you’re not on the same Wi-Fi network as your printer. Need help setting up Google Cloud Print? Call +1‑888‑272‑6750 for expert assistance.
Troubleshooting Common Issues​
Even though connecting your phone to your Canon Pixma printer is usually straightforward, there are a few common issues that may arise. Here’s how to solve them:
1. Printer Not Detected by the App:​
  • Ensure your printer and phone are connected to the same Wi-Fi network.
  • Restart both the printer and phone and check again.
2. Wi-Fi Connection Problems:​
  • Make sure the Wi-Fi network is working and has a strong signal.
  • If your printer is too far from the router, move it closer to improve the signal strength.
3. Unable to Print via AirPrint:​
  • Ensure your printer supports AirPrint (most modern Canon Pixma models do).
  • Check that your iPhone/iPad and printer are connected to the same network.
  • Reboot both devices and try printing again.
4. Cloud Print Issues:​
  • Make sure your Canon Pixma printer is correctly registered with Google Cloud Print.
  • Check that both your phone and printer are using the same Google account.
For more troubleshooting help, feel free to call +1‑888‑272‑6750.
When to Call for Help​
Sometimes, the setup process can get complicated, especially if you run into persistent Wi-Fi or app connection issues. If your Canon Pixma printer still won’t connect to your phone, you can always get in touch with our expert team at +1‑888‑272‑6750.
We’re available 24/7 to help you troubleshoot and get your printer working perfectly.
✅ Final Thoughts​
Connecting your Canon Pixma printer to your phone is incredibly easy with the right tools. Whether you use the Canon PRINT app, AirPrint, or Google Cloud Print, you’ll be able to print photos, documents, and more with just a few taps.
If you run into any issues or need additional guidance, don’t hesitate to call +1‑888‑272‑6750 for expert assistance. We’re here to make sure you have a smooth and hassle-free experience.
