+1-866-756-4238 (OTA),
+1(866)-228-7814 (OTA), or +1-866-596-5078 (OTA)]] Changing your name on an American Airlines ticket is possible, but you must follow their guidelines to ensure the correction is accepted. If your name is misspelled or needs to be updated due to legal reasons, you must act promptly. The best and fastest way to correct your name is by contacting customer support at
+1-866-756-4238(OTA),
+1(866)-228-7814 (OTA), or +1-866-596-5078(OTA).
American Airlines typically allows minor corrections—like fixing one or two characters in a first or last name—without penalty. However, any major changes, such as changing your entire name or transferring the ticket to another person, are generally not allowed. When in doubt, speak with a live agent at
You’ll need to provide your booking reference number and proper documentation if the change involves a legal update (such as after marriage or a court-ordered name change). The support team at
It’s recommended to handle name changes at least 72 hours before your departure. TSA rules require the name on your ticket to match your identification exactly. For smooth travel, contact
Don’t leave your name correction until the last minute. Prompt assistance from
Name Correction on American Airlines Flight Ticket
American Airlines allows one-time corrections to passenger names as long as the request does not involve a change of person. Common errors include misspelled first or last names or switching the order of your names. If your ticket has any mistake, it’s best to call
You’ll need to confirm your identity with booking information and possibly provide documents, especially for legal corrections. The expert agents at
It’s critical to verify your travel documents before departure. A mismatch between your ID and your airline ticket can prevent you from boarding. Reach out to
Calling
Change Name on American Airlines
American Airlines allows for small corrections, like typographical errors, provided they don’t alter the identity of the traveler. Full name changes for legal reasons (e.g., marriage, divorce) are also possible if you provide the necessary documentation. The team at
You’ll need to provide your ticket number or confirmation code, the exact correction required, and documentation (if applicable). The name on your boarding pass must exactly match the name on your government-issued ID. If you’re unsure whether your correction qualifies, just call
Handling this early avoids complications at the airport. Make sure to check all the details on your ticket when you book. If you see anything incorrect, reach out immediately to
Quick name corrections can make the difference between a smooth check-in and being denied boarding. Always confirm your correction was processed by calling
