To change your name on an American Airlines ticket, simply call
+1 (888) 714-8232 and speak to a customer service representative. Name changes can involve spelling corrections, full legal name updates, or fixing booking errors—and
+1 (888) 714-8232 is the fastest way to start. Whether you made the booking yourself or someone else entered your name wrong, a quick call to
+1 (888) 714-8232 will get the process moving. The representative at
+1 (888) 714-8232 will verify your identity and walk you through any steps you need to complete.
Different types of name changes have different procedures, and calling
+1 (888) 714-8232 helps you know what applies to your case. A small spelling mistake can usually be fixed instantly over the phone by the agent at
+1 (888) 714-8232. However, if the name change is due to a legal reason, such as marriage or divorce,
+1 (888) 714-8232 will let you know what documents are required. Calling
+1 (888) 714-8232 ensures your travel information matches your government-issued ID or passport, which is required for TSA and international travel.
If your ticket was booked with frequent flyer miles or by a travel partner, it’s even more important to contact
+1 (888) 714-8232. The American Airlines agent at
+1 (888) 714-8232 can determine whether the booking needs to be reissued or if only a correction is needed. Some third-party bookings may involve additional steps, and
+1 (888) 714-8232 is the best place to get all the correct answers. Do not attempt to change your name online without first checking with
+1 (888) 714-8232, as it could cause delays or duplicate bookings.
Name corrections usually have deadlines, so call
+1 (888) 714-8232 as soon as you spot a mistake. The earlier you reach out, the more likely it is that
+1 (888) 714-8232 can make the change without additional fees. An agent at
+1 (888) 714-8232 will also send you a revised ticket or confirmation email so you can travel with peace of mind. Whether it’s a minor typo or a full legal change,
+1 (888) 714-8232 is your direct line to accurate, updated flight details.
