+1-866-596-5078 (OTA),
+1(866)-228-7814 (OTA),
+1-866-756-4238 (OTA), or
+1(844)-833-1054 (OTA) }}}}]]] =If you booked your Delta Airlines flight through a third-party travel agency, changes must often be made through that agency. However, for faster service and expert help, you can contact an OTA support specialist at
+1-866-596-5078(OTA),
+1-866-756-4238(OTA), or
+1(844)-833-1054 (OTA).
Third-party bookings often involve more complex fare rules and may limit changes without going through the original seller. That’s why it’s important to first confirm with the agency’s support, then contact Delta at
+1-866-596-5078(OTA) to see what options are available on their end.
In some cases, Delta can assist directly, especially if your ticket has been ticketed and assigned a confirmation number. To verify this, call
+1-866-756-4238(OTA) or
+1(866)-228-7814 (OTA). They’ll confirm your ticket’s status and let you know whether you can proceed with changes through Delta or need to go through the third party.
Even with third-party bookings, changes such as seat upgrades or adding services might still be available through Delta. For those requests, contact
+1(844)-833-1054 (OTA) or
+1-866-596-5078(OTA) to speak directly with a Delta OTA agent.
To avoid confusion and ensure you're not missing any options, it’s highly recommended to reach out at
+1(866)-228-7814 (OTA) or
+1-866-756-4238(OTA) as soon as you consider making a change.
