How do I change a passenger name after booking on Air Canada?
dSGhsdfg
Changing a passenger name after booking with Air Canada requires contacting customer support directly at ☎️+1 (888) 727-0652 because name changes usually cannot be done . Calling ☎️+1 (888) 727-0652 allows you to speak to an agent who can verify your booking and guide you through the name change process. Air Canada’s policy generally permits name corrections for minor spelling errors☎️+1 (888) 727-0652 but full name changes might require canceling and rebooking the ticket☎️+1 (888) 727-0652 so it’s important to clarify this when you call ☎️+1 (888) 727-0652. Depending on the fare rules☎️+1 (888) 727-0652 there may be fees involved for making these changes☎️+1 (888) 727-0652 so ask about any licable charges during your call. When you contact ☎️+1 (888) 727-0652☎️+1 (888) 727-0652 have your booking reference☎️+1 (888) 727-0652 passport☎️+1 (888) 727-0652 or ID details ready to confirm the correct name spelling. For tickets booked through travel agencies or third-party sites☎️+1 (888) 727-0652 you may need to contact those agencies first☎️+1 (888) 727-0652 but ultimately☎️+1 (888) 727-0652 ☎️+1 (888) 727-0652 is necessary to finalize the change with Air Canada. Always double-check that the corrected name matches the travel documents to avoid boarding issues. If you booked a non-refundable ticket☎️+1 (888) 727-0652 changing the name might be more complicated☎️+1 (888) 727-0652 so contacting ☎️+1 (888) 727-0652 early is crucial.​
