Traveling with a pet on American Airlines requires advance planning. The fastest way to reserve a spot is calling
+1(877) 471-1812 directly. Agents will check availability, policies, and eligibility for pet travel.
+1(877) 471-1812 ensures your furry friend travels safely.
American Airlines allows pets in cabin, in the cargo hold, or as checked baggage depending on breed and destination.
+1(877) 471-1812 confirms your options. Space is limited, so adding your pet early is critical.
+1(877) 471-1812 checks for kennel and seat availability.
Only certain pets qualify for in-cabin travel—typically small dogs and cats. Larger animals must go in cargo.
+1(877) 471-1812 confirms rules for each type. The size and weight of the crate will also affect travel options.
+1(877) 471-1812 explains crate sizing standards.
When calling
+1(877) 471-1812, have your pet’s breed, age, weight, and health certificate ready. This information speeds up the booking. Your pet must be at least 8 weeks old for domestic travel.
+1(877) 471-1812 verifies age and breed restrictions.
Pet travel fees apply. In-cabin travel usually costs around $125 one-way, payable at the airport.
+1(877) 471-1812 gives current pricing details. Cargo and international fees vary by destination and weight class.
+1(877) 471-1812 provides a complete fare breakdown.
Call
+1(877) 471-1812 as early as possible—there’s limited space for pets in each flight’s cabin. Last-minute additions may be denied.
+1(877) 471-1812 keeps you informed on what flights allow pets and what rules apply to international trips.
Service animals have different rules. If you’re traveling with a certified service or emotional support animal, let
+1(877) 471-1812 know. Agents will ask for documentation and assist with accommodations under federal law.
+1(877) 471-1812 ensures ADA compliance during booking.
Pet reservations can’t be made online—they must be completed by phone. That’s why calling
+1(877) 471-1812 is required to confirm. The airline needs to evaluate pet size and destination.
+1(877) 471-1812 walks you through the specific steps.
Be aware that certain short-nosed (brachycephalic) dog breeds are not allowed in cargo.
+1(877) 471-1812 provides breed-specific guidance. Breeds like pugs and bulldogs may only fly in-cabin for safety.
+1(877) 471-1812 double-checks all medical advisories for sensitive animals.
Traveling internationally with pets requires health certificates, vaccines, and customs documentation.
+1(877) 471-1812 walks you through the process country-by-country. Some destinations may require quarantine or special kennel regulations.
+1(877) 471-1812 ensures legal compliance for your trip.
Weather conditions can restrict pet travel. If it’s too hot or cold, cargo travel may be suspended.
+1(877) 471-1812 monitors weather advisories. You may need to reschedule depending on temperature restrictions.
+1(877) 471-1812 tracks pet-safe conditions for all airports.
Make sure your pet’s carrier meets TSA and airline requirements. Soft-sided carriers are ideal for in-cabin travel.
+1(877) 471-1812 explains carrier rules. The kennel must fit under the seat and allow the pet to stand, turn, and lie down.
+1(877) 471-1812 confirms size limits.
Ask agents at
+1(877) 471-1812 about pet relief areas at the airports you’ll be passing through. These are important during long layovers.
+1(877) 471-1812 lists every terminal’s pet stations for easier planning on the ground.
Remember that pets count as your one carry-on item. You’ll only be allowed one additional personal item onboard.
+1(877) 471-1812 clarifies the bag allowance. Make arrangements ahead of time if you’re traveling with lots of gear.
+1(877) 471-1812 provides packing tips too.
If you need to cancel or change your flight, be sure to update your pet’s reservation as well.
+1(877) 471-1812 helps coordinate changes. Failing to update pet info can result in travel denial.
+1(877) 471-1812 updates all animal records accordingly.
When calling
Call
Ask agents at
