horn doesnt work....
san supra
833
san antonio
i got no voltage to either horn while pressing on the steering wheel.
i replaced the relay, thought it wold fix it.
what else can i check?
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
the horn itself? ground it to something and touch the positive on the the + battery terminal.. should sound if its working. if it works, double check wiring and relay.. and ground point?
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
Take horn pannel off sterring wheel. Identify horn wire (or prong if you have cruise control, 3 prong plug iirc.), It should have power. Connect it to the positive lead of a multimeter set to Volts DC. Connect the negative lead to a good ground. If you read 0 then your problem is before the horn button, not after. Check TSRM for wiring diagrams.
5
Can also jump the wires on the connector on the underside of the steering column. More than likely it's the contact that allows the steering wheel to turn. Do the other buttoms on your steering wheel work?
modmonster2008
mod crazy yo!
Sep 9, 2008
1,051
Seattle, WA
if all else fails, then the contact ring has bad connectivity, try to rip that apart and clean/sand the terminals with very very fine sandpaper, then the terminals would have good connection again
te72
Classifieds Moderator
6,624
9
WHYoming
In the meantime, a quick stab of the throttle can do the trick too. ;)
barkz
363
Afghanistan
do your hazards work? last i looked the fuse under the hood is listed as HORN/HAZARD...just a thought. no horns in mine, and the OP put a MOMO wheel in without even trying to hook up the horn button. so the other day i just bought a BADBOY horn from autobone, and ran wires and a relay. lol sounds like a ferrari horn
