I think this might be a pretty dumb question, but I can't seem to get a consistent answer from the people I have talked to.
I am doing a rebuild right now, and like anyone, the last thing I want to do is spend more money than needed. Is it possible to just hone the cylinders without boring them out and reuse the stock pistons? Or would this remove too much material?
I was reading that the hone should remove .003" to .005" so I am assuming that the cyl clearances would be checked, and if they have that much room left on tolerance, and the surface isn't badly marked up, they can simply be honed and the stock pistons reused..
Good idea/bad idea? Comments?
