hit and run
Alex91Mk3
timeshares exchange
Jun 30, 2006
276
Miami, Fl
I'm form Miami and for some reason its been raining alot, well i got into a little hit and run where i stopped for a dog in the middle of the street and a pick-up hit me with a grill hit me in the back. i chased for about 7 minutes in neighborhoods and busy streets but he started going over medians and ofcourse we all know... us supras cant do that, so he escaped. well when it rains kinda hard... the back seat behind the passenger gets a little wet at the bottom, where could the water be getting in through, by the way this happened almost a year ago, since then its been repainted and fixed but the frame is still pushed back a centimter, i can tell because the hatch goes just a little more in than the body when its closed... anyways... water...seat...leak?
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
Check the rubber seal around the hatch. You can also take off the rear headliner behind the targa and check. he may have cracked the putty that holds the hatch to the body.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
its the hatch seal. mine is literally falling down where the top of the hatch and roof meet and it leaks in there.
Wayne G.
87Turbo 5sp Targa
Apr 19, 2005
213
Gainesville,Ga.
In my supra it driped in from the targa top. Removed the top used lots of
silicon spray on the rubber - carfuly tightend the top per the owners manual
sequence and it stoped. (was in Orlando when Charley blew thru and it put
a half inch of water the the rear floorboard passanger side --
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i bet you have rust hole take the back seat out and look for water comon place for it to rust si the top or middle of the insaid wheels wheel take some stock out fo the back and find out i bet that is your issue
