HIGH RPM's at Idle-PLEASE HELP
noremacsupra
beginner
Jan 29, 2007
85
Los Angeles
Hello,
Yesterday i was driving/racing my 90 turbo just around the neighborhood and then i noticed that suddenly my car would idle higher than normal. Before it idle at 650-800 now it idles 1200-1450. The next morning it idle fine but as soon as i started running it again it kicked to high rpms at idle. Also, after starting the car when the engine is warm/hot - it idles normally but after a few seconds the RPM'S go higher again.
Thanks for the help.
Noremac25
1990 Toyota SUPRA Turbo MT (stock engine-short ram air intake only)
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
Jaguar_5 said:
Have you checked the simple things? Like see if the throttle cable is sticking somewhere
It only does it when warm, meaning its probably not the throttle cable.
Most likely its your ISC that is malfunctioning when it gets hot. Electronics do that alot.
noremacsupra
beginner
Jan 29, 2007
85
Los Angeles
It idles fine when just started. then when i start driving it it goes up...thanks..
