High heat paint?
chriso
Supranian
Bay Area, CA
What kind of high heat paint do you guys use (if any is available) for painting up exhaust manifolds, turbo elbows, etc...that see in excess of 1200F.
QWIKSTRIKE
475rwhp459torq an climbin
Apr 3, 2005
1,172
Some where out there
Autozone has the one with ceramic in it. Its good up to 2000 degrees I think, but I am not to sure; However I use it on my turbine housing and down pipe and it holds up great. You must bake it on the turbine housing. The down pipe I couldnt get into the oven So I let it dry, and then just mounteted it. They look and work flawlessly.
suprageezer
778
Southern California
If you dont mind a gray nickle like color, just for fun, clean a small area on your manifold, coat it with nickle anti-seize, drive it around till the oils burn out and you'll see a nice nickle coated area that wont corrode now.
